Unable to install DBD::Oracle
jstoddart
Post by jstoddart »
Trying to get the Oracle Plugins working on a Nagios XI Server running CentOS 5 but the cpan -i DBD::Oracle returns this:
dbdimp.c: In function ‘fb_ary_cb_alloc’:
dbdimp.c:322: warning: comparison is always false due to limited range of data type
dbdimp.c:323: warning: comparison is always false due to limited range of data type
dbdimp.c:324: warning: comparison is always false due to limited range of data type
dbdimp.c:325: warning: comparison is always false due to limited range of data type
dbdimp.c:326: warning: comparison is always false due to limited range of data type
dbdimp.c: In function ‘fb_ary_alloc’:
dbdimp.c:342: warning: comparison is always false due to limited range of data type
dbdimp.c:343: warning: comparison is always false due to limited range of data type
dbdimp.c:344: warning: comparison is always false due to limited range of data type
dbdimp.c:345: warning: comparison is always false due to limited range of data type
dbdimp.c: In function ‘ora_st_FETCH_attrib’:
dbdimp.c:4355: error: ‘imp_dbh’ undeclared (first use in this function)
dbdimp.c:4355: error: (Each undeclared identifier is reported only once
dbdimp.c:4355: error: for each function it appears in.)
make: *** [dbdimp.o] Error 1
/usr/bin/make -- NOT OK
Running make test
Can't test without successful make
Running make install
make had returned bad status, install seems impossible
Have attached the full output
Re: Unable to install DBD::Oracle
Post by slansing »
You need to install MAKE first, so that you can compile the module. You should have it already on the XI server, It's curious you are getting this error. What is the output of:
yum list installed | grep make
jstoddart
Post by jstoddart »
[:main.Centos5_641 ~]# yum list installed | grep make
automake.noarch 1.9.6-2.1 installed
automake14.noarch 1.4p6-13 installed
automake15.noarch 1.5-16 installed
automake16.noarch 1.6.3-8 installed
automake17.noarch 1.7.9-7 installed
imake.x86_64 1.0.2-3 installed
make.x86_64 1:3.81-3.el5 installed
Post by slansing »
What instant client version did you install, and what is the output of:
cat /proc/version
echo $ORACLE_HOME
echo $LD_LIBRARY_PATH
jstoddart
Post by jstoddart »
Linux version 2.6.18.8-xenU (root@applogicbuild64) (gcc version 4.1.1 20070105 (Red Hat 4.1.1-52)) #1 SMP Wed Feb 3 11:28:48 PST 2010
[KANA-LON-NAGIOSX1:main.Centos5_641 ~]# echo $ORACLE_HOME
/usr/lib/oracle/11.2/client64
[KANA-LON-NAGIOSX1:main.Centos5_641 ~]# echo $LD_LIBRARY_PATH
/usr/lib/oracle/11.2/client64/lib/
Post by slansing »
Sorry, I should have had you run this as well:
lscpu | grep Architecture
ll /usr/lib/oracle/11.2/
I just wanted to verify that you had the correct env variables and paths for your architecture.
jstoddart
Post by jstoddart »
No problem.
lscpu does not exist on the server?
[KANA-LON-NAGIOSX1:main.Centos5_641 ~]# ll /usr/lib/oracle/11.2/
total 4.0K
drwxr-xr-x 4 root root 4.0K Apr 23 10:33 client64/
Odd that lscpu is not listed. Try this:
cat /proc/version
I believe there was a bug in CPAN's DBD::Oracle
https://github.com/pythian/DBD-Oracle/issues/14
Not 100% sure, but it looks like it may have just been fixed based on the above thread. Can you try the install again to see if it works correctly for you now?
jstoddart
Post by jstoddart »
Ok will try:
cat /proc/version
