Hello everybody,
I need to make a .exe file that check of the given up multicast stream is availible.
I need to check this with NRPE.
I am writing in C#. I already make the code for checking if the multicast stream is availble.
This is working fine. But i don't know how or what i need to return so NSClient can return this with NRPE to my Nagios server.
Do you guys know any of this?
Thanks.
Have a nice day,
Zamykiller
C# check
Re: C# check
Yes, the plugin must provide an exit code and status output for each exit, the possible codes are 0,1,2,3. You can see the requirements here:
https://nagios-plugins.org/doc/guidelines.html
