Nagios XI Version : 2012R2.9
CentOS release 6.5 (Final) 64 bit
VMware image
We are trying to monitor an application process using WMI and the check_xi_service_winplus (this is what the wizard automatically selected when choosing to monitor a WMI host). We are running in $ARG3$ checkprocess and we are running in $ARG4$ -sCommandline -a "PROCESSNAMEHERE.EXE".
It correctly tells us how many instances of that process we have running but when it hits ZERO we want it to issue a warning and or an error so we can investigate.
I can't figure out anywhere to set something like that and I can't even find the checkprocess argument command in documentation.
Thanks!
WMI Host Wizard Process Monitoring (Won't issue error)
Re: WMI Host Wizard Process Monitoring (Won't issue error)
You need a space between your flag and it's value "-s Commandline".
I'd recommend you test this from the command line before setting up checks, that way, we can give you commands to try as we troubleshoot your issue.
Sorry that was a typo. There is a space there. The command works properly but what I need it to do is when the process count drops below 1 (AKA not running) to trigger a warning or error alert in Nagios. When we shutdown the process it shows as 0 running instances but doesn't issue a warning.
in $ARG4$ add
Which means it will be critical if it is outside the range of 1 to infinity
So $ARG4$ should look like
-c 1:So $ARG4$ should look like
-s Commandline -a "PROCESSNAMEHERE.EXE" -c 1:Re: WMI Host Wizard Process Monitoring (Won't issue error)
Perfection! Thanks so much!
