iptables and NCPA Client on RHEL6
juana
Post by juana »
NCPA client on RHEL6 and iptables on does not work for me. If I stop iptables service, then the '/etc/init.d/ncpa_listener restart' works. Otherwise, the Nagios master node gets UNKNOWN errors from client. Is there a special rule I need to add to allow NCPA to talk to master node while iptables is enabled?
Re: iptables and NCPA Client on RHEL6
Post by slansing »
Port 5693 by default needs to be open, what to you get when you run this from the XI server?:
nmap -sU -p 5693 addr.of.remote.ncpa.box
juana
Post by juana »
# nmap -sU -p 5693 my.hostname.ext
Starting Nmap 5.51 ( http://nmap.org ) at 2014-04-28 11:14 PDT
Nmap scan report for my.hostname.ext (xx.xx.xx.xx)
Host is up (0.00021s latency).
PORT STATE SERVICE
5693/udp filtered unknown
Nmap done: 1 IP address (1 host up) scanned in 2.08 seconds
Post by slansing »
Looks like you have not provided a firewall rule for NCPA, it is still filtered. That is up to you or your sysadmins to take care of. Without that port open, or the port that you set NCPA to use, you will not be able to send or receive over it.
juana
Post by juana »
Thanks, I ran the below and all is well:
 /sbin/iptables -I INPUT -p tcp -m tcp --dport 5693 -j ACCEPT
/sbin/service iptables save
If all is well for you then all is well for us. I'll be closing this thread now, but feel free to open another if you need anything in the future!
