Exchange Configure Guide
thomasjbs
Post by thomasjbs »
is there a guide to configuring Exchange Clients? The default install doesn't work.
Perhaps there is a DIFFERENT client for Exchange servers?
I installed the host first - which worked, then I found the wizard later and installed the Client on both Exchange servers (Mail and CAS). The results were the same as listed below (mostly "Connection Refused?")
The Firewall is turned off.
Many "Exchange Services" failed with
Then I:
1) Uninstalled all SERVICES for Exchange
2) Deleted all Exchange hosts
3) Applied the configuration successfully
4) Re-Installed using the Wizard
OWA Monitoring and SMTP work fine every time, but Exchange Core Services, Exchange Core Web, IMAP, Messages pending routing all Fail.
Firewall on Exchange and CAS servers are turned off.
Re: Exchange Configure Guide
The Exchange wizard relies on the following agent for those checks
http://library.nagios.com/library/produ ... dows-agent
