sudo tcpdump -vvv -A dst port 5667
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
14:48:58.212123 IP (tos 0x0, ttl 128, id 27254, offset 0, flags [DF], proto TCP (6), length 52)
10.11.100.200.51201 > 10.11.100.20.nsca: Flags [S], cksum 0xc886 (correct), seq 606971717, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
E..4jv@....[
.d.
.d....#$-.E...... .................
14:48:58.212750 IP (tos 0x0, ttl 128, id 27255, offset 0, flags [DF], proto TCP (6), length 40)
10.11.100.200.51201 > 10.11.100.20.nsca: Flags [.], cksum 0x4a89 (correct), seq 606971718, ack 2341622318, win 256, length 0
E..([email protected]
.d.
.d....#$-.F..R.P...J.........
14:48:58.324339 IP (tos 0x0, ttl 128, id 27256, offset 0, flags [DF], proto TCP (6), length 760)
10.11.100.200.51201 > 10.11.100.20.nsca: Flags [P.], cksum 0x3c1c (correct), seq 0:720, ack 133, win 256, length 720
E...jx@.....
.d.
.d....#$-.F..R.P...<......
K.n..:s..\.r.. ...2..0R..=wW.....`9|B.W..a..Pi.>N".. .n.guF.:}+...V.....ARSk".!b.7.c.EY-.....N'......[E.E.....U?.Qj.1....Ev='<<0...&..VSx...X......p..V.G...d.......rM...$......7.....* ...q...x.....<......qt~..........]......K,.2r.kZ5j.......".(.j.c}.
....}.S...|.<.5cI..+(.....X^1)....'...t.?.6.|d7.........,a..A......^.......G..F...|....uS.....g..>..y...x/[email protected].;...{..14S..>..x..B.......S.p.Y.%RA...Cl.{.e9|.A.!c./.;L4.M.L...).....`....#..{...l.Kk.g~....,&..9.'.. ...{.G.....9wi.P.....4.=.
14:48:58.324366 IP (tos 0x0, ttl 128, id 27257, offset 0, flags [DF], proto TCP (6), length 40)
10.11.100.200.51201 > 10.11.100.20.nsca: Flags [F.], cksum 0x4734 (correct), seq 720, ack 133, win 256, length 0
.d.
.d....#$-....R.P...G4........
14:48:59.322930 IP (tos 0x0, ttl 128, id 27259, offset 0, flags [DF], proto TCP (6), length 40)
10.11.100.200.51201 > 10.11.100.20.nsca: Flags [.], cksum 0x4733 (correct), seq 721, ack 134, win 256, length 0
E..(j{@....b
.d.
.d....#$-....R.P...G3........
^C
5 packets captured
5 packets received by filter
0 packets dropped by kernel
That is the full nsclient.ini file. Is it missing something?
