Fusion performance graph dashlet doesn't pull data from XI
This support forum board is for questions relating to Nagios Fusion.
lxf4610
Post by lxf4610 »
Hi All,
I'm new here, just start to use fusion. Get stuck to use performance graph dashlet to show the graph for host or service from XI. The web content looks just loading when I added it into dashboard and it never end ...
Appreciate for any suggestion :?: :P
Re: Fusion performance graph dashlet doesn't pull data from
Post by slansing »
Can you provide an image of the specific dashlet you were trying to add? Had you tried to clear the browser's cache? Is anything else in the web interface behaving sluggishly or improperly to your knowledge?
lxf4610
Post by lxf4610 »
Hi slansing,
Thanks for the reply. Yes, I tried to clear the cache but it didn't work. The dashlet that not working is just the built-in Performance Graph and Time Stacked Performance Graph.
Run the following command on the Fusion server and show us the output.
tail -50 /var/log/httpd/error_log
jomann
Development Lead
Post by jomann »
This is a bug that has been fixed and will be in the new release of Fusion.
I have attached some files for you to replace these dashlets. Upload the attached zip files to "Admin > Manage Dashlets" to overwrite your version of the dashlets.
lxf4610
Post by lxf4610 »
Thanks, looks it fix the issue in my side with the new version :lol:
lxf4610
Post by lxf4610 »
BTW, a small question, looks even if with the new version of Time Stacked Performance Graph, it doesn't allow choose time period. Always be 3 days.
It seems like this is also a bug - I was able to recreate the issue and will be filing an internal bug report.
Update this was fixed in 2014R1.0 of Fusion
