Hi - We are getting this error for couple of Disk checks
"UNKNOWN - could not locate mountpoint /data/srcweb on host" - Can you please help us find the solution. This was working on the past.
Regards
Ruban
Check_disk_snmp - Return unknown
Re: Check_disk_snmp - Return unknown
Let's make sure that mount point is actually present. Run this on the monitored host and post the output:
mountFormer Nagios employee
