Parent/child is indeed the first thing I will setup and put on a dashboard when Nagios arrives. I'm curious if anyone has found this to be helpful when T/S'ing a path through all your infrastructure (switches, routers, F5's)? Our webshop is having entire F5 pools going red (offline per the health monitor). I think it's the VM's they are on but would like to show with a graph of the data path from outside through the network to the F5 that there is never a problem at an intermediate step.
What I'm not sure of is if the map lends itself well the the entire network path, any experience anyone with this?
Organizing Hosts Services and Contacts
Reason: I have split your post into a new topic
Re: Organizing Hosts Services and Contacts
Yeas, and the map does a fine job. What you need to remember is that parent-child relationships are configured from the nagiso server's perspective. I also find that using dummy hosts to represent transparent networking devices can be used to identify when those transparent devices are possibly down (as all children will be red).bobnamac wrote:What I'm not sure of is if the map lends itself well the the entire network path, any experience anyone with this?
Thanks. Would you mind defining "from the point of view of Nagios"? Is it the only entity that can be the center of the network?
Essentially, yes. The nagios server cannot be a child of another object. All objects are children of nagios.bobnamac wrote:Is it the only entity that can be the center of the network?
