How to monitor system with VPN connect to another network?
We have a Windows 7 system that monitors a security system at a customer site. It need to stay connected to that site at all times via VPN, we want to know when the VPN connection goes down. So I figured since I cannot ping it while it's connected via VPN, I could try to setup Nagios to notify me when we ARE able to ping it, since that would mean the VPN. I put the following in my windows.cfg file, but either that's not where it goes or my syntax is all wrong.
define servicedependency{
host_name WindowsTest
service_description WinBackOnlineTest
dependent_host_name WindoowsTest
dependent_service_description WinBackOnlineTest2
execution_failure_criteria n
notification_failure_criteria o
I am new to Nagios Core (v4) and it's been a while since I've been in linux command line, so please bear with me. Any help would be greatly appreciated. Also, is there documentation that explains where certain settings , like "define service{" go in to which *.cfg file? Thanks in advance.
-Adam
-Adam
sreinhardt
- -fno-stack-protector
Re: How to monitor system with VPN connect to another networ
Well the service dependency is not what you are looking for if you need a new ping service for that host. Do you already have a host configuration and if so what check command are you using there? It really sounds like you can do a host with no services since you just want to ping it.
OK, I just put the define host{ for the test machine in the windows.cfg file, there is also another define host{ entry for a web server. It still shows all the services for the test machine on the webpage eventhough I only have define service{ entries for the web server.
sreinhardt
Could you provide the definitions we are talking about. It's nearly impossible to diagnose this without such information.
# WINDOWS.CFG - CONFIG FILE FOR MONITORING A WINDOWS MACHINE
# HOST DEFINITIONS
# Define a host for the Windows machine we'll be monitoring
# Change the host_name, alias, and address to fit your situation
use windows-server ; Inherit default values from a template
host_name web ; The name we're giving to this host
alias web ; A longer name associated with the host
address 192.168.1.26 ; IP address of the host
host_name WindowsTest ; The name we're giving to this host
alias WindowsTest ; A longer name associated with the host
address 192.168.1.19 ; IP address of the host
# HOST GROUP DEFINITIONS
# Define a hostgroup for Windows machines
# All hosts that use the windows-server template will automatically be a member
of this group
define hostgroup{
hostgroup_name windows-workstations ; The name of the hostgroup
alias Windows Workstations ; Long name of the group
members web
# SERVICE DEFINITIONS
# Create a service for monitoring the version of NSCLient++ that is installed
# Change the host_name to match the name of the host you defined above
service_description NSClient++ v0.4.1.90
check_command check_nt!CLIENTVERSION
# PING host
service_description PING
check_command check_ping!200.0,20%!600.0,60%
normal_check_interval 5
retry_check_interval 1
# Create a service for monitoring the uptime of the server
service_description Uptime
check_command check_nt!UPTIME
# Create a service for monitoring CPU load
service_description CPU Load
check_command check_nt!CPULOAD!-l 5,80,90
# Create a service for monitoring memory usage
service_description Memory Usage
check_command check_nt!MEMUSE!-w 80 -c 90
# Create a service for monitoring C:\ disk usage
service_description C:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l c -w 80 -c 90
# Create a service for monitoring the W3SVC service
#define service{
# use generic-service
# hostgroup_name windows-workstations
# service_description W3SVC
# check_command check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
# Create a service for monitoring the Explorer.exe process
service_description Explorer
check_command check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
}Re: How to monitor system with VPN connect to another networ
So now, instead of just wondering how to monitor WindowsTest for only successful pings, not failed, and notify me, I'm now wondering why I'm still getting the services list for it when I dont have any service for it in the .cfg file?
What services specifically? It looks like it's probably pulling them in via the hostgroup.
C: space
CPU load
Mem usage
PING
Uptime
CPU load
Mem usage
PING
Uptime
By the config files above, "192.168.1.26" is currently being checked for what looks like all of those noted services. So it sounds like what you are experiencing is expected because of how you have the hostgroup tied to those services.
But I'm getting the services listed for 192.168.1.19 also and it's not in the hostgroup definition.
