In reference to my earlier post, there is indeed a way how to use user's mobile phone (or any other information) in your custom commands.
Please see the code below for some ideas.
If you uncomment the lines in the end, you will get all metadata of the specific user.
Regards,
Tamar
#!/usr/bin/php -q
<?php
require_once('/usr/local/nagiosxi/html/includes/components/componenthelper.inc.php');
if ($argc > 1) {
print "Username: $argv[1]\n";
$user_id = get_user_id($argv[1]);
print "ID: $user_id\n";
$user_name = get_user_meta($user_id, "name");
print "Name: $user_name\n";
$user_mobile_number = get_user_meta($user_id, "mobile_number");
print "Mobile number: $user_mobile_number\n";
else {
print "No username was passed.\n";
exit(1);
//$all_user_meta = get_all_user_meta($user_id);
//var_dump($all_user_meta);
