Hi there,
My notifications work well for all my infrastructure using Host Template. Here my issue, im trying to add a specific contact on a specific host for a custum notification. This contact must not have all the notification from the Template, only a few host on handle by this Template.
When i add the contact directly to the host, the contact in the Template assosiated with it dont get the notification.
What the best way to do that plz.
Regard
PO
Host Notifications
Re: Host Notifications
This is standard behavior, any configuration option that you specify in a template will be over ruled by one that you define on a host/service object itself, I would recommend adding the contacts from those templates to the object for these special cases.
http://nagios.sourceforge.net/docs/3_0/ ... tance.html
