We are using Nagiosxi 2012 R2.9 and as Nagiosxi 2014 beta has been released. Can you tell me how we can migrate our exist server which is on 32bit platform into Nagiosxi 2014.
First of all I would highly suggest not upgrading your production server to a BETA. BETA's are prone to bugs, and are a test bed for new features, they should not be used as a primary source for monitoring your infrastructure. I'd recommend using one of your 3 available license activations to create a testing server, and install the beta directly to there.
Second, if you are moving from 32-bit to 64-bit you need to follow the backup and restore document. The issue here is that you will need to convert your RRD's to 64-bit or you will lose your performance data.
As per your documentation i have migrated my old Nagiosxi 2012 2.9 (32 bit OS) to Nagiosxi 2014 R1.0 (64 bit OS), then i add same ip to new server and used same Offloaded Database server, , Everything was looking ok, but after some time i noticed that all hosts status are not updating and even when i try to add another new host it's showing processed ok but host is not showing there.
Here is my scenario:
Existing Configuration New Configuration
OS: Centos 5.4 32bit Centos 6.5 Final 64 bit
Nagiosxi 2012 R2.9 Offloaded Mysql server
Offloded Mysql server Nagiosxi 2014 R1.o
CPU: 4 core CPU: 4 core
RAM: 16 GB RAM: 16 GB
I attached the config file, please tell me what is going on?
