I have nagios installed and working great on CentOS 6. My Nagios version is 3.5.1
I was wondering how i can update to the newest version. Do i have to do it in certain steps or can i just update straight from 3.5.1.
Also how can i do this without losing my current configs?
I am also a linux/nagios beginner so any help would be appreciated
Regards
Will
Upgrading from 3.5.1 to 4.0.6
Re: Upgrading from 3.5.1 to 4.0.6
Yep, you can do it safely, all you would essentially be doing is re-compiling Core:
http://assets.nagios.com/downloads/nagi ... Source.pdf
I would of course make backups of your configurations, or any data you feel relevant.
willholt89
ok i have followed that guide, but now i get internal server error on any links i click within the nagios web gui.
The homepage states that it is unable to get process results
Please Advise
Will
Please Advise
Will
willholt89
I have successfully resolved my issue.
The internal server error issue i was having was due to SELinux.
I disabled that using the following command
I then encountered an issue that where nagios didnt have permissions for the /usr/local/nagios/var/rw/ directory.
I rectified this using the following commands
Thank you for your help thus far
Regards
Will
setenforce 0I rectified this using the following commands
chown nagios:nagcmd /usr/local/nagios/var/rw
chown nagios:nagcmd /usr/local/nagios/var/rw/nagios.cmdRegards
Will
Excellent! We're going to lock this thread up for now, if you have new questions feel free to open a new thread! Thanks!
