Does anybody know the OID to monitor the power supply of DELL Power connect 7048 Switch`?
I tried this .1.3.6.1.4.1.674.10895.5000.2.6132.1.1.43.1.7.1.2 but this doesnt work.
DELL powersupply OID
Re: DELL powersupply OID
You should have that information listed in the user manual, or you should be able to get it via contacting dell. You may also be able to attain this by looking at the MIBs for your device, or running SNMP walk against it:
Replace 2c with your version, if using SNMPv3 you will need your auth priv information.
snmpwalk -v 2c -c communitystringhere addr.of.dell.switchRe: DELL powersupply OID
I didn't find anything relevant but if no one has it handy I will find a way. Thanks.
Sorry we couldn't be more help. OIDs are device-specific and there are only so many devices we have in-house.
