i have install nagios 4.0 on a server and its working fine for localhost after that i have setup a linux host to monitor
when i added to nagios and went to see from web interface, its showing me following error for every service .
CPU Load
CRITICAL 05-08-2014 11:43:03 0d 1h 37m 29s 3/3 (Return code of 255 is out of bounds)
Current Users
CRITICAL 05-08-2014 11:44:21 0d 1h 36m 12s 3/3 (Return code of 255 is out of bounds)
FTP Monitoring
CRITICAL 05-08-2014 11:46:00 0d 1h 34m 33s 3/3 (Return code of 255 is out of bounds)
SSH Monitoring
CRITICAL 05-08-2014 11:43:25 0d 1h 35m 54s 3/3 (Return code of 255 is out of bounds)
Total Processes
CRITICAL 05-08-2014 11:45:33 0d 1h 35m 0s 3/3 (Return code of 255 is out of bounds)
while i am running the command on linux host to check the services its fine and providing expected results.
but not working from nagios server.
can u please help me to figure out and resolve this issue.
Ovais alam
sreinhardt
- -fno-stack-protector
Re: Return code of 255 is out of bounds
What are the permissions on those files, on the remote system? Also are you using an agent or check_by_ssh to check that system remotely?
its resolved.
issue was with the nrpe
i added the server ip in remote hosts's nrpe.cfg file. its works now.
Good to hear. I'll close this up now.
