After installing Nagios XI and performing 2 Auto-Discovery operations, I started to manually run Manual device discoveries. After performing a couple of these, Nagios will not successfully perform another scan/manual discovery. In addition, it is failing when trying to save the monitoring config.
Any thoughts would be appreciated.
Sachmo
Nagios XI does not allow continued setup
Reason: Please do not open duplicate threads, every new user must have their initial threads approved by moderators before they get posted, opening duplicate threads will only slow this process down.
Re: Nagios XI does not allow continued setup
Are you receiving an error while trying to set up an auto-discovery job? Do you have multiple jobs running concurrently? You will want to fix those configuration errors, one way to tell exactly what is causing the error is to navigate to CCM > Tools > Write Configs Tool > Verify. This should spit out the errors in your configurations and tell you what is missing or what needs to be changed.
Hi slansing:slansing wrote:Are you receiving an error while trying to set up an auto-discovery job? Do you have multiple jobs running concurrently? You will want to fix those configuration errors, one way to tell exactly what is causing the error is to navigate to CCM > Tools > Write Configs Tool > Verify. This should spit out the errors in your configurations and tell you what is missing or what needs to be changed.
The verify and write ran without error. I redid thje Manual scan again and it still failed. See below, I verified the SNMP config on the server is valid.
Linux SNMP Monitoring Wizard
Configuration submitted for processing...
Waiting for configuration verification.........
Configuration verification failed.
Configuration Error
An error occurred while attempting to apply your configuration to the monitoring engine. Contact your Nagios administrator if this problem persists.
Run this monitoring wizard again
Run another monitoring wizard
View the latest configuration snapshots
Sach
Clicking "View the latest configuration snapshots" will bring you to a page that will show your last 20 configs, whether successful or failed. For the latest failed one you will want to click the View Output button and see where the verification if failing. Paste the output here.
