I've noticed that the home screen displays dashlets differently in IE as apposed to Firefox after resizing a dashlet.
From what I can tell, if I resize a dashlet from Firefox then both IE and Firefox look the same. If I resize a dashlet from IE then IE looks fine but Firefox displays differently. See screenshots:
The problem does not occur if I move the dashlet around.
Bug: Home screen appears differently for IE and Firefox
- Box293
- Too Basu
Re: Bug: Home screen appears differently for IE and Firefox
We will look into this sizing issue.
There are a few differences between how IE and firefox will handle the dashlets. This is due to the different way IE handles/support object properties compared to other browsers.
We identified a few patches to help with some resizing issues under IE, but there will always be slight differences in looks between IE and other browsers I'm afraid...
Ethan Galstad
President
Ethan Galstad
President
