Monitoring a script
Monitoring a script
Hello, I have a problem and ask for help to users of this forum. I have a bash script that alerts me on the number of files that are generated in a folder. The script contains 3 outputs : exit 0 : all ok , exit 1 : motion has been detected (indicating that generated file in the folder ) , exit 2 : there are many files. Well, after this, edit the / etc / snmp / snmpd.conf file and add an snmp judgment and invoking the script execution. Then put the nconf nagios alarms and my particular case I use a snmp_check . Well, my problem is that always snmp_check returns the OK message is generated or not files inside the folder. My question is how I can using a nagios plugin , run my script and monitor the status of that folder in real time. For more information the script check the size of the folder where the video capture generated by the daemon motion are kept. Thanks for your help .
Re: Monitoring a script
You are going to need to put some more detail into the question.
What do you mean by:
The below is, again, confusing, what do you mean by this? Are you looking for an alternative to do this that is already created?:
http://exchange.nagios.org/
What are you putting there?edit the / etc / snmp / snmpd.conf file and add an snmp judgment and invoking the script execution.
What are you using to trigger this? What is the command you are using, and the plugin you are using? Are you wrapping your plugin in another?Then put the nconf nagios alarms and my particular case I use a snmp_check
If looking for an alternative I'd recommend searching the exchange:My question is how I can using a nagios plugin
