Hi, we have a problem when upgrade to the 2014R1.0 version.
When installation is finished and nagios starts, the monitor engine is down.
When we try to start the engine, have a lot of errors:
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects..... in hosttemplates.cfg
Error: Service has no hosts and/or services_description
Can you help me?
ERROR - Upgrading from 2012R2.9 to 2014R1.0
rbaholding
Re: ERROR - Upgrading from 2012R2.9 to 2014R1.0
There should be more output than that. Can you post the full output? It should mention the file that has the host/service_description issue.Error: Service has no hosts and/or services_description
rbaholding
Hi again,
Finally, we could upgrade Nagios but we have another problem.
All seems OK, but the monitor engine process doesn't start. Ever is down.
The nagios.cfg verification is allright. What info or logs do you need for help me?
Thanks a lot.
Thanks a lot.
What output do you receive when you try to start nagios?:
service nagios startCode: Select all
tail -30 /usr/local/nagios/var/nagios.logCode: Select all
tail -30 /var/log/messages-
rbaholding
Hi, I attached the requested logs.
Thanks.
Thanks.
Looks like MK-Livestatus is failing, this is because of a bug they have regarding Core 4, you will need to use version "1.2.0p3" of livestatus in order to use it with Nagios XI.
http://support.nagios.com/forum/viewtop ... 2&start=20
rbaholding
Hi, We have applied mklivestatus 1.2.0p3 version and nagios still not working.
Only works if remove the "broker" line of charge the mklivestate in nagios.cfg but nagvis don't works.
Any idea?
Any idea?
sreinhardt
- -fno-stack-protector
To confirm, you also recompiled and installed the new broker module for mk? Let's also make sure that there is only one mk module on the system.
updatedb
locate livestatus.oNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
