Hi folks,
After a fresh install of nagios-X1, r5; when we log into the web-interface. At the top left corner of the page, under system-ok it shows a information mark 'i' for active_checks, passive_checks and Notifications. Mouse-roll-over states the mesg as 'Active Host Checks Are Disabled'. The first three buttons are green.
any reason why this is happening and how to recover from it?
thank you
Abhijit
Active checks are disabled
[email protected]
Last edited by [email protected] on Fri Jul 08, 2011 3:24 pm, edited 1 time in total.
[email protected]
Re: Active checks are disabled
Hi folks,
We were able to identify that the problem is in the E-script
The php -q nagiosql_login.php; does not generate the nagiosql_login file
Any idea why this is happening.... We do not have PHP expertise available to guide us.
