-bash: check_nrpe: command not found
Mandar
Post by Mandar »
I am using Nagios XI. I issued following command from the Nagios Server:
nagiossrv root [libexec] > check_nrpe -H 128.19.5.131 -t 30 -c check_users -w 5 -c 10
It is giving me following error:
I have also added the IP address of the Nagios server (nagiossrv) to the /usr/local/nagios/etc/nrpe.cfg file at the host's (128.19.5.131) side.
What is the issue?
Re: -bash: check_nrpe: command not found
Instead of running this:
try running this:
./check_nrpe -H 128.19.5.131 -t 30 -c check_users -a '-w 5 -c 10'
