Hi Joe,
You might have to define host as well in templates for example If I want to monitor Switch -
In Template.cfg I should have : ""define host and define service""
# Define a template for switches that we can reuse
name generic-switch ; The name of this host template
use generic-host ; Inherit default values from the generic-host template
check_period 24x7 ; By default, switches are monitored round the clock
check_interval 5 ; Switches are checked every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each switch 10 times (max)
check_command check-host-alive ; Default command to check if routers are "alive"
notification_period 24x7 ; Send notifications at any time
notification_interval 30 ; Resend notifications every 30 minutes
notification_options d,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
register 0 ; DONT REGISTER THIS - ITS JUST A TEMPLATE
# Generic service definition template - This is NOT a real service, just a template!
name generic-service ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
is_volatile 0 ; The service is not volatile
check_period 24x7 ; The service can be checked at any time of the day
max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
normal_check_interval 10 ; Check the service every 10 minutes under normal conditions
retry_check_interval 2 ; Re-check the service every two minutes until a hard state can be determined
contact_groups admins ; Notifications get sent out to everyone in the 'admins' group
notification_options w,u,c,r ; Send notifications about warning, unknown, critical, and recovery events
notification_interval 60 ; Re-notify about service problems every hour
notification_period 24x7 ; Notifications can be sent out at any time
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
and switch.cfg should have:
# Define the switch that we'll be monitoring
use generic-switch ; Inherit default values from a template
host_name HOST1 ; The name we're giving to this switch
alias Stack Serverroom ; A longer name associated with the switch
address 10.10.10.1 ; IP address of the switch
hostgroups switches
# Create a new hostgroup for switches
define hostgroup{
hostgroup_name switches ; The name of the hostgroup
alias Network Switches ; Long name of the group
# Monitor uptime via SNMP
use generic-service ; Inherit values from a template
host_name HOST1
service_description Uptime
check_command check_snmp!-C public -o sysUpTime.0
