Hi all,
We @graydon Netherlands has installed NagiosXI in RedHat.
It is a machine with multiple nics .10.130.206.127 and 172.16.200.140.
The installations has added the website to ip-adres 10.130.206.127 but it must be on the 172.16.200.140 adress
http://10.130.206.127/nagiosxi/ is unreachable for us @graydon
How do we change the initial ip adress from the command box?
We are not able to browse to 10.130.206.127 because it is the internal ipadress from our provider.
thanks in advance.
installing NAGIOS XI on machine with multiple nics
HelpdeskGraydon
Re: installing NAGIOS XI on machine with multiple nics
You should be able to go to
http://172.16.200.140/nagiosxi/ as well
Then, once setup, make sure to check the correct addresses in Admin -> Manage System Config
HelpdeskGraydon
Thanks for the reply.
Indeed it works.
Thanks.
Indeed it works.
Thanks.
It sounds like this is resolved then? Are you good to close the thread?
