[SOLVED] first_notification_delay doesn't work
falken
Post by falken »
Hello everyone,
I am running nagios core 3.5.1 on centos 6.5 x64 installed from epel repo.
I'm a bit confused that option 'first_notification_delay' doesn't work for me.
I tried to setup different time period, but none of it worked except for 0 which is default according to documentation
Here is my service config:
        host_name                       server.hostname
        service_description             pure-ftpd_procs
        is_volatile                     0
        max_check_attempts              3
        normal_check_interval           5
        retry_check_interval            1
        contact_groups                  admins
        first_notification_delay        3
        notification_interval           120
        notification_options            u,c
        check_command               check_nrpe!check_proc_ftp
My time_unit is default, which is 60.
I didn't found anything about it here, google doesn't know anything except for old bugs.
Can anyone please explain how to set this right?
Best regards.
sreinhardt
-fno-stack-protector
Re: first_notification_delay doesn't work
Post by sreinhardt »
The notification delay, is simply a number of minutes(generally) that notifications wait from the last OK state before they will send, not waiting after the hard warn\critical. If your retry interval X check attempts is larger than the delay interval it will never be noticed as we would already be past that time period.
falken
Post by falken »
Thanks for explaining.
Just to be clear, i'll provide an example:
1 service(status ok), time 10:00 -> first_notification_delay 10(minutes)->service(critical), time 10:10-> no notification?
and working scheme:
1 service(status ok), time 10:00 -> first_notification_delay 20(minutes)->service(critical), time 10:10-> receive notification after 10 minutes of critical state?
Best regards,
You haven't changed the interval_length's value from the default of 60, have you?
grep interval_length /usr/local/nagios/etc/nagios.cfg
falken
Post by falken »
Nope, i didn't. It's 60
falken wrote:Hello,
and working scheme:
Best regards,
I think this post will show explain your situation
The time for "first notification delay" is timed based on the last known OK state
not from the first failure
So if you normally check on 5 minute intervals the service would reach a HARD state at
5 + 3 + 3 + 3 = 14
Being you have your "first notification delay" set to 13 it would be sent immediately.
If you want the notification to go out 13 minutes after it goes into a hard state, set it to 27.
falken
Post by falken »
Thank you for the advice. I solved my issue, but i used a bit different scheme.
For anyone who will need, here is my service config:
        host_name                       hostname
        service_description             My service
        is_volatile                     0
        first_notification_delay        15
        contact_groups                  mygroup
        notification_interval           30
        check_command                   check_service
Note that i have set: normal_check_interval to 5, retry_check_interval to 1, and first_notification_delay to 15.
So for now i receive notification after 10 minutes for CRITICAL state, as i figured, this is the logic:
After expiration of max_check_attempts and normal_check_interval there are only 10 minutes left till the notification will be sent.
Marking this thread as solved, thank you very much guys. Couldn't do it without your support :)
Best regards.
