i worke with eyesofnetwork (centos 6.4) i want to configure postfix in order to receive mails in my adress gmail
how can i do it ?
and is there a method to configure notification through the graphic interface eonweb ?
notification emails
sreinhardt
- -fno-stack-protector
Re: notification emails
While nagios can use postfix as one of many different mailing options, it is outside of the scope of our forums to configure the actual server. However once you do, you should basically be able to set it as your local mta and nagios will use this by default. Are you having any particular issues with the configuration or simply looking for help getting started?
i get started with the notification of main.cf of postfix. i added these lignes
after this configuration i restart the service postfix using the command
the adresse 74.125.232.149 is the adress of gmail.com (i am not sure if it is correct but i found that the value of relayhost should be the adresse of your mail )
in addition to that , i add my e-mail in the file contacts.cfg of nagios
i restart the nagios with the commande
when i test the command
i receive that i had a new message in the file /var/spool/mail/root
if i acceed to this file i receive undelivered message retur to the sender
what can i do to receive e-mails in my adress gmail ?
please help me
myhostname = localhost.localdomain
mydomain = localdomain
myorigin = $myhostname
default_transport = smtp
relayhost = 74.125.232.149Code: Select all
/etc/init.d/postfix restart in addition to that , i add my e-mail in the file contacts.cfg of nagios
service nagios restartCode: Select all
echo "test | mail -s "test postfix mail" [email protected]if i acceed to this file i receive undelivered message retur to the sender
please help me
Could you not send the mail directly with sendmail?
Have you tried asking for postfix help on their mailing list: http://postfix.1071664.n5.nabble.com/Po ... rs-f2.html
the command sendmail is not working
what can i do to receive e-mails :/
Like abrist said, you might have better luck on the postfix forums. We really don't do much with it aside from the automatic installation, so unless configs have been modified we tend not to get questions on it. I would suggest looking in your /var/log/maillog for any hints as to what might not be working.
