e-mail notification shows alias instead of hostname
MichielvM
Post by MichielvM »
I give up, I've scrounged this forum, found numerous related issues and solutions, none of which apply to my situation.
We have some 30 XI servers, all setup following the same procedure.
Be that as it may, I see differences in email notifications. Some servers (most) show email notifications with the correct hostname in the email subject and body text, whereas others (a few large ones) show alias in the subject and body.
Like this:
***** Nagios Monitor XI Alert *****
Notification Type: PROBLEM
Service: <any old service>
Host: [b]windows server 2008 - iis - sql[/b]
Address: <ipaddress>
State: CRITICAL
So far I crosschecked with 4 servers:
- Notification Commands (notify-host-by-email and notify-service-by-email)
- Clicked username and Notification Messages
- Notification Settings Management
The variable used is %host%
I checked the actual Hosts and Services CFG files.
Everything is exactly the same, except for the final e-mail.
What am I missing??
For the record: we're using version 2012R2.5 and a few 2.9.
Re: e-mail notification shows alias instead of hostname
Nagios XI users don't use notify-host-by-email and notify-service-by-email notification handlers. They use xi_host_notification_handler and xi_service_notification_handler. Contacts only use notify-host-by-email and notify-service-by-email notification handlers but they cannot modify their notification options (Notification Messages)...
I would recommend reading the following two documents:
http://assets.nagios.com/downloads/nagi ... ntacts.pdf
http://assets.nagios.com/downloads/nagi ... ations.pdf
Find out who is the xi user or the "contact only" receiving these alerts, then check what notification handlers he/she is using. If this is a user, check the user's Notification Options.
I am moving this topic to the Nagios XI support. It seems like you posted on the Nagios Core forum by mistake.
MichielvM
Post by MichielvM »
It looks like "notify service by email" handler is the culprit here.
$HOSTALIAS$ in one, and $HOSTNAME$ in another.
What I don't understand is that I have different versions of these handlers.
All our XI servers are built from scratch using a predefined procedure.
Any thoughts on that score?
abrist
Red Shirt
Post by abrist »
MichielvM wrote:All our XI servers are built from scratch using a predefined procedure.
The notify-*-by-email commands are from core, so I would presume that they are configured in core with $HOSTALIAS$. Changing $HOASTALIAS$ to $HOSTADDRESS$ or $HOSTNAME$ should resolve your issues.
