Nagios 2014 XI R 1.0
costanza2k1
Post by costanza2k1 »
When doing a verify I get this:
Reading configuration data...
Warning: use_embedded_perl_implicitly is deprecated and will be removed.
Warning: sleep_time is deprecated and will be removed.
Warning: p1_file is deprecated and will be removed.
Warning: external_command_buffer_slots is deprecated and will be removed. All commands are always processed upon arrival
Warning: enable_embedded_perl is deprecated and will be removed.
Warning: command_check_interval is deprecated and will be removed. Commands are always handled on arrival
Read main config file okay...
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/hosttemplates.cfg', starting at line 14)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/hosttemplates.cfg', starting at line 136)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/servicetemplates.cfg', starting at line 14)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/servicetemplates.cfg', starting at line 117)
Any suggestions on how to clear out these failures, when I clear them out from the .cfg file it seems as if the come right back and in correlation the monitoring engine resets itself. Your help is appreciated.
abrist
Red Shirt
Re: Nagios 2014 XI R 1.0
Post by abrist »
Did the upgrade run successfully? These deprecated options should have been removed by the sql.
costanza2k1
It ran succesfully with no issues. I'm noticing the monitoring engine restarting itself every few minutes now. Do you recommend I run the upgrade again?
Yes, you can run the upgrade again - it won't hurt anything. Do you see "Nagios XI 2014R1.0" on the bottom of the page? Any oddities on the "Monitoring Process" page (Home->Process Info)?
costanza2k1
It does have Nagios XI 2014R1.0, the Monitoring Process is resetting itself every 2-7 minutes...
Did you try rerunning the upgrade?
costanza2k1
lmiltchev wrote:Did you try rerunning the upgrade?
no we didn't but we removed those entries manually...showing zero errors now.
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Checking objects...
Checked 1324 services.
Checked 179 hosts.
Checked 137 host groups.
Checked 2 service groups.
Checked 41 contacts.
Checked 4 contact groups.
Checked 113 commands.
Checked 47 time periods.
Checked 0 host escalations.
Checked 179 hosts
Checked 0 host dependencies
Checked 47 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
keeping an eye on the monitoring engine process now. I'll keep you guys posted.
We'll keep this open for a week or so.
costanza2k1
Just a follow up here, I ended up running the upgrade again on Friday and the engine has been stable ever since...
Post by slansing »
Excellent... we will keep this open a bit longer, let us know if you start to see issues...
