Which user were you testing this as? Does the nagios user have access to write to the temp files? Could you also list how it is defined in the service and command definitions?
sreinhardt wrote:Which user were you testing this as? Does the nagios user have access to write to the temp files? Could you also list how it is defined in the service and command definitions?
I now used the macros $NAGIOS_HOSTSTATE, $NAGIOS_HOSTNAME and now everything works fine.
