Another switch monitoring wizard question for 2014R1.0
- snapon_admin
I just tried running the switch wizard in 2014 for the first time, and My contacts/contact groups section is coming up blank, but there's definitely contacts and contact groups on my server.
Re: Another switch monitoring wizard question for 2014R1.0
What version of the switch & router wizard are you using at this point? I just checked a system that was upgraded from 2.9 to 2014 r1.0 and mine are appearing just fine.
- snapon_admin
It was using version 2.0.1, but I saw the other post here that had the 2.0.5 version. The updated one wasn't meant to address the issue I was having, but since I was having this problem in 2.0.1 I figured I'd update and see if that fixed it. No dice.
- snapon_admin
Hmm, it looks like this might have only affected the first run through the wizard. I canceled out of it and started the wizard over again and all the contacts and groups showed up fine. I've re-run the wizard about 6 times now and gotten contacts every time so maybe just a weird hiccup for the first run through. This can be closed now up I think.
I'm glad your issue has been resolved! I am locking this topic. If you have more issues/questions, please, start a new thread.
