Nagios Performance Data w/ DNX
ormsbeec
Post by ormsbeec »
Hey All,
I dont think this is a nagios problem; but the mailing list for DNX is a little slow so I though I would ask here. I plan to use dnx to offload my checks on a production nagios server that will eventually be home to at least 50k service checks and possibly into the 100k range.
The problem is any check offloaded to dnx strips all performance data, does any one know if there is some kind of setting to allow this data not to be stripped?
mguthrie
Re: Nagios Performance Data w/ DNX
Post by mguthrie »
http://assets.nagios.com/downloads/nagi ... ng_DNX.pdf
DNX does not handle distribution of load for non-check work, like performance graphing
We don't currently have that process documented, but I definitely understand why you'd want the performance data. What you'd essentially have to do is intercept the performance data from the check results before DNX strips it, but we don't have a procedure like that documented.
