check_xi_mssql_query showing warning on Query results matche
AssecoSee
Post by AssecoSee »
Hi
I've done upgrade to Nagios XI 2014R1.0.
I'm using check_xi_mssql_query with query i've used for a while on previous version of Nagios XI and it always worked fine till now.
I did not change anything in configuration or SQL script i'm running but when i get Query results matched, nagios xi is showing Warning instead of OK status.
Help?
Re: check_xi_mssql_query showing warning on Query results ma
Can you show us the actual command that you are running from the command line, along with the output of it? Hide sensitive info.
