After 2014 upgrade, host notifications disabled
SavaSC
Post by SavaSC »
Just updated to XI 2014. After logging in I noticed that "Open Service Problems" was empty. (There were about 9 or so before I updated.) I checked All Service Problems and there they were. On that Service Status page, all of the hosts listed with service problems are showing as Notifications are Disabled, however, if I click on the link to the host, it is not disabled in that view. If I go to Host Detail, none of the hosts are listed with Disabled Notifications. This seems to be showing only in the All Service Problems area. When a new service error shows up, the host is marked as Notifications Disabled even though we've not touched it.
*Note* The services with errors aren't marked as disabled notifications, but rather the hosts themselves.
How can I get these hosts back to normal and to show up under "Open Service Problems"?
Thank you!
SavaSC
Re: After 2014 upgrade, host notifications disabled
Post by SavaSC »
Here is the profile file downloaded from Admin -> System Profile.
Post by slansing »
Your update may not have completed properly, what is the output of:
/usr/local/nagios/bin/nagios | head -2
/usr/local/nagios/bin/ndo2db | head -2
service ndo2db stop
service nagios stop
service nagios start
service ndo2db start
tail -30 /usr/local/nagios/var/nagios.log
tail -30 /var/log/messages
tail -30 /var/log/mysqld.log
Please run the above in that order.
SavaSC
Post by SavaSC »
I get a screen full of of the following lines:
140521 13:24:01 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed
Run the following commands:
./repairmysql.sh nagios
./repairmysql.sh nagiosql
then run:
tail -25 /var/log/mysqld.log
and show us the output.
When you go to: Admin->System Profile, what is the number of hosts/services that you see?
Run the following commands and show us the output:
SavaSC
Post by SavaSC »
Sorry it took me so long to respond. I was not in the office yesterday.
The output for the mysqld.log is:
140523 12:36:36  InnoDB: Shutdown completed; log sequence number 0 43655
140523 12:36:36 [Note] /usr/libexec/mysqld: Shutdown complete
140523 12:36:36  mysqld ended
140523 12:37:22  mysqld started
140523 12:37:22 [Warning] option 'max_join_size': unsigned value 18446744073709551615 adjusted to 4294967295
140523 12:37:23  InnoDB: Started; log sequence number 0 43655
140523 12:37:23 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.0.77'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  Source distribution
140523 12:37:50 [Note] /usr/libexec/mysqld: Normal shutdown
140523 12:37:52  InnoDB: Starting shutdown...
140523 12:37:53  InnoDB: Shutdown completed; log sequence number 0 43655
140523 12:37:53 [Note] /usr/libexec/mysqld: Shutdown complete
140523 12:37:53  mysqld ended
140523 12:37:53  mysqld started
140523 12:37:53 [Warning] option 'max_join_size': unsigned value 18446744073709551615 adjusted to 4294967295
140523 12:37:53  InnoDB: Started; log sequence number 0 43655
140523 12:37:53 [Note] /usr/libexec/mysqld: ready for connections.
Here is the rest of the output you requested.
Nagios Core 4.0.5
NDO2DB 2.0.0
And here is the info from Nagios
Nagios XI Installation Profile
Download Profile
System:
Nagios XI Version : 2014R1.0
ltc099l 2.6.18-164.9.1.el5 i686
CentOS release 5.4 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.1.6
Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:29.0) Gecko/20100101 Firefox/29.0
Server Name: hou-nagiosxi
Server Address: 10.90.18.24
Server Port: 80
Date/Time
PHP Timezone: America/Chicago
PHP Time: Fri, 23 May 2014 12:40:17 -0500
System Time: Fri, 23 May 2014 12:40:17 -0500
Nagios XI Data
License ends in: TOPQPN
nagios (pid 2254) is running...
NPCD running (pid 3789).
ndo2db (pid 2345) is running...
CPU Load 15: 0.31
Total Hosts: 0
Total Services: 0
Function 'get_base_uri' returns: http://hou-nagiosxi/nagiosxi/
Function 'get_base_url' returns: http://hou-nagiosxi/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://hou-nagiosxi/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Did you run the following commands like lmiltchev asked?:
SavaSC
Post by SavaSC »
Yes, I did.
Your mysql database is not offloaded to a remote server, is it? Where did you run the repair script? Can you restart mysqld again and show the log?
service mysqld restart
You still have "0" hosts and services in the profile...
Total Hosts: 0
Total Services: 0
SavaSC
Post by SavaSC »
To the best of my knowledge the MySQL instance is running on the same box as this Nagios instance. I just inherited the program, I didn't build it. I have looked through the documentation we have and nothing indicates there is any outside database.
I stopped and started the msqld service and here is an output of the log.
140523 14:41:57  InnoDB: Shutdown completed; log sequence number 0 43655
140523 14:41:57 [Note] /usr/libexec/mysqld: Shutdown complete
140523 14:41:57  mysqld ended
140523 14:41:58  mysqld started
140523 14:41:58 [Warning] option 'max_join_size': unsigned value 18446744073709551615 adjusted to 4294967295
140523 14:41:58  InnoDB: Started; log sequence number 0 43655
140523 14:41:58 [Note] /usr/libexec/mysqld: ready for connections.
140527  8:12:37 [Note] /usr/libexec/mysqld: Normal shutdown
140527  8:12:39  InnoDB: Starting shutdown...
140527  8:12:40  InnoDB: Shutdown completed; log sequence number 0 43655
140527  8:12:40 [Note] /usr/libexec/mysqld: Shutdown complete
140527 08:12:40  mysqld ended
140527 08:12:41  mysqld started
140527  8:12:41 [Warning] option 'max_join_size': unsigned value 18446744073709551615 adjusted to 4294967295
140527  8:12:41  InnoDB: Started; log sequence number 0 43655
140527  8:12:41 [Note] /usr/libexec/mysqld: ready for connections.
I am not sure why it says zero hosts and services. There are over a hundred hosts with their respective services being monitored from this instance of NagiosXI.
Thanks for all the help so far.
