Error on time periods after upgrade to nagiox xi 2014R1.0
rramos
Post by rramos »
Hello all, after upgrade from Nagios XI 2012 to Nagios XI 2014R1.0 I faced the error Error: The timeperiods '24x7' and '24x7' form or lead into a circular exclusion chain! when try to Apply Configuration. Have you already faced this issue before ?
Re: Error on time periods after upgrade to nagiox xi 2014R1.
Post by slansing »
Where does your configuration verification show this error occurring?:
rramos
Post by rramos »
Follow the error message, it complains about Time Periods.
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 221
Complete output
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Reading configuration data...
Warning: use_embedded_perl_implicitly is deprecated and will be removed.
Warning: sleep_time is deprecated and will be removed.
Warning: p1_file is deprecated and will be removed.
Warning: external_command_buffer_slots is deprecated and will be removed. All commands are always processed upon arrival
Warning: enable_embedded_perl is deprecated and will be removed.
Warning: command_check_interval is deprecated and will be removed. Commands are always handled on arrival
Read main config file okay...
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 220)
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 221.
What do you have in '/usr/local/nagios/etc/timeperiods.cfg' on line 221? You need to fix the error in the CCM, run the Write Config Tool to make sure you don't have any more errors, then apply configuration.
