We're trying to install the latest version of NagiosXI on a fresh system. This is the error I encounter after running the install script.
Nagios XI Installation Log
DATE: Tue May 20 20:25:04 EDT 2014
DISTRO INFO:
RedHatEnterpriseServer
6.5
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=2014R1.0
major=2014
minor=R1.0
releasedate=2014-05-13
release=403
Configuring Yum...
package centos-release is not installed
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-6-server-optional-rpms
This machine was registered through Red Hat Subscription Manager. But I was unable to add "Optional" channel via web or CLI.
Also tried the YUM command but failed.
[root@bcsnsnagios1 nagiosxi]# yum-config-manager --enable rhel-6-server-optional-rpms
Loaded plugins: product-id, refresh-packagekit, rhnplugin
This system is receiving updates from RHN Classic or RHN Satellite.
Please advise.
Thanks, -klee
NagiosXI 2014R1.0 install error
Re: NagiosXI 2014R1.0 install error
Please, review our FAQ wiki page in regards to this issue here:
http://support.nagios.com/wiki/index.ph ... ptions..22
Worked perfectly, please close thread.
-klee
-klee
