Upgrade from Nagios XI 2012R2.8c to Nagios XI 2014 failed
toper
Post by toper »
I'm trying to upgrade from Nagios XI 2012R2.8c to Nagios XI 2014, but upgrade fails with - "Running configuration check... CONFIG ERROR! Restart aborted."
The XI part is still XI 2012R2.8c with fail - Monitoring Engine not running, and not possible to start it. So i think the fail is on the Core upgrade part.
I read in another thread that it could be old ghost host or services causing this problem. I have checked the file dates in /usr/local/nagios/etc/hosts
and /usr/local/nagios/etc/services, and all files seems to be up to date.
I then restored my latest backup, and things works again.
Please find attached logs.
thanks,
Peter Calum, TDC
Denmark
Peter Calum
toper
Re: Upgrade from Nagios XI 2012R2.8c to Nagios XI 2014 faile
Post by toper »
I forgot :
For all support requests, we need to know:
Linux Distribution and version? -
Red Hat Enterprise Linux Server release 6.5 (Santiago)
Linux khk9dsg25.ip.tdk.dk 2.6.32-431.11.2.el6.x86_64 #1 SMP Mon Mar 3 13:32:45 EST 2014 x86_64 x86_64 x86_64 GNU/Linux
32 or 64bit? 64 bit
VMware Image or Manual Install of XI? - Manual install on plain base RHEL
Are there special configurations on your system, ie; is Gnome installed? - No
Are you using a proxy? - No
Are you using SSL? - No
thanks,
Peter Calum
Peter Calum
toper
Post by toper »
Problem Solved !!
I upgraded again and ran the config check..
I corrected this Error
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/ssh_check_raid_M1.cfg', starting on line 14)
Then a new ./upgrade with SUCCES :D
[root@khk9dsg25 nagiosxi]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/hosttemplates.cfg', starting at line 14)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/hosttemplates.cfg', starting at line 154)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/servicetemplates.cfg', starting at line 14)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/servicetemplates.cfg', starting at line 116)
thanks,
Peter Calum
TDC Denmark
Peter Calum
