Linux NRPE install
Sbergonzi
Linux NRPE install
Post by Sbergonzi »
Continued....
The error in my last post was resolved (registration with RedHat) however the nrpe is not available. Does this get placed by the install or is it placed by another install?
Re: Linux NRPE install
Do you have any "installed." files in the "/tmp/linux-nrpe-agent" directory? If you do, remove all of them and rerun the fullinstall.
Sbergonzi
Post by Sbergonzi »
that worked, ok to close
