Hi. Just wondering if anyone has had success with checking to see if the exchange store is OK post reboot (exchange 2007)? Would appreciate any/all help.
A way to check for mounted drives in exhcange 2007
Re: A way to check for mounted drives in exhcange 2007
Did you try looking on our Nagios Exchange? There is a check_exchange plugin that might be what you are looking for.
