Help needed - Nagios setup not working
manju
Post by manju »
not required
Nagios error.docx
(52.31 KiB) Downloaded 300 times
eloyd
Cool Title Here
Re: Help needed - Nagios setup not working
Post by eloyd »
5. Nagios installation
This step is most likely your problem. Did it actually complete properly? Is nagios running? Is Apache running?
It looks mostly like Apache doesn't know about the /nagios directory, which implies that Apache has not been restarted since the configuration changes done during Nagios install were made.
Could you also post/PM the last 20 lines or so of your http error log?
tail -20 /var/log/httpd/error_log
That "<" after the error message is a bit odd.
