Post Upgrade Process State won't turn green
At0mrail
Post by At0mrail »
Ran the upgrade successfully. Now we cannot change the process state from red to green. HELP!!!!
Re: Post Upgrade Process State won't turn green
Run the following commands and show us the output:
service nagios status
service ndo2db status
/usr/local/nagios/bin/nagios | head -2
/usr/local/nagios/bin/ndo2db | head -2
Are you using Mod Gearman, Livestatus, etc.?
At0mrail
Post by At0mrail »
Last login: Fri May 23 14:06:20 2014 from 172.16.1.77
[root@clcsrv117 ~]# service nagios status
nagios is not running
[root@clcsrv117 ~]# service ndo2db status
ndo2db (pid 1462) is running...
[root@clcsrv117 ~]# /usr/local/nagios/bin/nagios | head -2
Nagios Core 4.0.5
[root@clcsrv117 ~]# /usr/local/nagios/bin/ndo2db | head -2
NDO2DB 2.0.0
[root@clcsrv117 ~]#
Ok, found this in the nagios log. This shows up when restarting the monitoring engine. something in there it doesn't like.
[1400872029] ndomod registered for retention data'
[1400872029] ndomod registered for contact data'
[1400872029] ndomod registered for contact notification data'
[1400872029] ndomod registered for acknowledgement data'
[1400872029] ndomod registered for state change data'
[1400872029] ndomod registered for contact status data'
[1400872029] ndomod registered for adaptive contact data'
[1400872029] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
[1400872029] Error: Module loading failed. Aborting.
You didn't answer my question:
Can you post the nagios.cfg file?
abrist
Red Shirt
Post by abrist »
Run a verification:
Post the output.
At0mrail
Post by At0mrail »
login as: root
root@clcsrv117's password:
Nagios Core 4.0.5
NDO2DB 2.0.0
[root@clcsrv117 ~]# ^C
[root@clcsrv117 ~]# /usr/local/nagios/bin/nagios -v /usr/local/etc/nagios/etc/nagios.cfg
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Reading configuration data...
Error: Cannot open main configuration file '/usr/local/etc/nagios/etc/nagios.cfg' for reading!
Error processing main config file!
Nagios Core 4.0.5
License: GPL
[root@clcsrv117 ~]#
We are thinking that we have to upgrade mod gearmon. Where and how are the next questions...
Can you confirm the permissions of the following file
ls -l /usr/local/etc/nagios/etc/nagios.cfg
Also can you verify disk space
df -h
df -i
At0mrail
Post by At0mrail »
We ended up updating ModGearman. That seems to have solved that issue.
Of course now some of my service checks (server uptime) aren't working.
Good times, good times.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Are those checks that are normally processed by gearman or something else like passive checks? Also just to confirm, verify now completes without any errors?
