Upgrade to Nagios 2014 failed
RIDS_I2MP
Post by RIDS_I2MP »
We are trying to upgrade to Nagios XI 2014R1.0 from Nagios XI 2012R2.8c, however we have ended up with error message "make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.5'
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
After this when we tried to restart the nagios service it failed to start and ended up with error message to check the confihegurations. We have now restored the Nagios XI using the backup and verified the config files with No warning or Error messages. We have tried the upgrade again but ended up with the same error message. I have attached the install log for your reference, please suggest.
install_log_latest.txt
Thanks & Regards,
I2MP Team.
RIDS_I2MP
Re: Upgrade to Nagios 2014 failed
Post by RIDS_I2MP »
We have done some testing on our side and understood that the error comes up after nagios core is upgraded. Nagios service is being restarted after the core upgrade as per the script and we get this message just after the command is executed.
When we run the verify after upgrade we get the below output.
Reading configuration data...
Warning: use_embedded_perl_implicitly is deprecated and will be removed.
Warning: sleep_time is deprecated and will be removed.
Warning: p1_file is deprecated and will be removed.
Warning: external_command_buffer_slots is deprecated and will be removed. All commands are always processed upon arrival
Warning: enable_embedded_perl is deprecated and will be removed.
Warning: command_check_interval is deprecated and will be removed. Commands are always handled on arrival
Read main config file okay...
Thanks & Regards,
I2MP Team.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Can you run and return the full output please:
RIDS_I2MP
Post by RIDS_I2MP »
Below is the output.
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Thanks & Regards,
I2MP Team.
Go to the CCM->Tools->Write Config Files->Click on "Write" and "Verify" and show us the output after each click in code wraps.
Also, run the following command and show us the output:
/usr/local/nagios/bin/ndo2db | head -2
RIDS_I2MP
Post by RIDS_I2MP »
Please find the requested details below.
Write Configuration Files
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
Verify Congifuration Files
Nagios Core 4.0.5
License: GPL
/usr/local/nagios/bin/ndo2db | head -2 - Output
[root@serv1 nagiosxi]# /usr/local/nagios/bin/ndo2db | head -2
NDO2DB 2.0.0
[root@srv1 nagiosxi]#
Thanks & Regards,
I2MP Team.
sreinhardt
Looks like your nagios.cfg has some invalid definitions or another . Could you post the nagios.cfg please?
RIDS_I2MP
Post by RIDS_I2MP »
Attached the Nagios.cfg file.
Thanks & Regards,
I2MP Team.
abrist
Red Shirt
Post by abrist »
First of all, if you have not updated mod_gearman for core 4, you should comment out the line:
broker_module=/usr/lib64/mod_gearman/mod_gearman.o config=/etc/mod_gearman/mod_gearman_neb.conf eventhandler=no
And stop the gearman services:
service gearmand stop
service mod_gearman_worker stop
Now run a verify and post the output:
RIDS_I2MP
Post by RIDS_I2MP »
As specified we have done but still the service is failing to start.
[root@xxxx etc]# service gearmand status
gearmand is stopped
[root@xxx etc]# service mod_gearman_worker status
mod_gearman_worker is not running
[root@xxx etc]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.5
License: GPL
Thanks & Regards,
I2MP Team.
