graph template line color
brandon.pal
Post by brandon.pal »
Hey All,
I've created a custom disk check that analizes % free on all disks and outputs the data. Check works great. I've also created a custom graph that shows all disks in one graph. I'm using a loop to get all the drives added to one graph.
My questions is how can I get the color of the line to change in each loop iteration. I've tried adding an if and case statement into the loop but as soon as I do that my graph dies.
Any ideas?
My Current Graph Code is:
<?php
$arrayCount=count($DS);
$opt[1] = "--vertical-label \"% Used\" -l0 --title \"Disk Space Usage for $hostname / $servicedesc\" ";
for($i=1; $i<=$arrayCount; $i++) {
  $def[1] .= "DEF:$NAME[$i]=$rrdfile:$DS[$i]:AVERAGE " ;
  $def[1] .= "LINE1:$NAME[$i]#0000FF:\"\"$NAME[$i] " ;
  $def[1] .= "GPRINT:$NAME[$i]:LAST:\"%3.2lf $unit[i] CUR \" ";
  $def[1] .= "GPRINT:$NAME[$i]:MAX:\"%3.2lf $unit[i] MAX \" ";
  $def[1] .= "GPRINT:$NAME[$i]" . ':AVERAGE:"%3.2lf $unit[i] AVG \j" ';
Re: graph template line color
Post by Box293 »
You could create an array of colors before running the loop and then use the $i to reference the color in the array.
For example:
$colors = array(
 1 => "#0000FF",
 2 => "#00FFFF",
 3 => "#FFFFFF"
then inside the for statement:
  $def[1] .= "LINE1:$NAME[$i]".$colors[$i].":\"\"$NAME[$i] " ;
Something along those lines
If the amount of disks is unknown, create an array of about 20 colors so that it'll always work.
brandon.pal
Works perfectly. THANK YOU :D
Closing as solved.
