I have installed nagios 3.0.6 and nsca-2.7.2 along with mcrypt-2.5.8 (CSWlibmcrypt) on a solaris 10 i386 box, and all the compilation went well, but whenever I run the test script that uses send_nsca I get the following client error :
Error: Server closed connection before init packet was received
Error: Could not read init packet from server
A server error appears in /var/adm/messages:
Jul 11 13:06:19 rozrhappt01-mont nsca[13793]: [ID 334271 daemon.error]
Could not open mcrypt algorithm 'blowfish' with mode 'cfb'
Other crypto algorithms fail in the same way.
However, the test works with plain XOR option=1.
Other info
$ uname -a
SunOS nagios-server 5.10 Generic_144489-04 i86pc i386 i86pc
Can anyone help me out, please.
(An earlier post by someone else shows no answer:
http://www.mail-archive.com/nagios-user ... 05768.html
nsca/mcrypt problem on Solaris 10
Re: nsca/mcrypt problem on Solaris 10
Problem solved.
The root cause was a "toxic mcrypt package" on my Nagios server, apparently an unstable release from Blastwave.
My solution is replacing this package with an earlier release from the stable tree.
Sad the Blastwave is not so active any more.
Toxic package:
Working package, readily available:
Toxic package:
$ pkginfo -l CSWlibmcrypt
PKGINST: CSWlibmcrypt
NAME: libmcrypt - MCrypt is a replacement for the old crypt() package and crypt(1) command, with extensions.
CATEGORY: application
ARCH: i386
VERSION: 2.5.8,REV=2008.11.25
BASEDIR: /
VENDOR: http://downloads.sourceforge.net packaged for CSW by Remko de Vrijer
PSTAMP: remko@thor-NOTVERSIONED-20081125195049
INSTDATE: Jun 08 2009 15:15
HOTLINE: http://www.blastwave.org/bugtrack/
EMAIL: [email protected]
STATUS: completely installed
FILES: 17 installed pathnames
8 shared pathnames
8 directories
3 executables
164 blocks used (approx)Code: Select all
NAME: libmcrypt - GPL replacement for Unix crypt that supports a wide range of algorithms and modes
CATEGORY: system
ARCH: i386
VERSION: 2.5.8,REV=2008.02.21
BASEDIR: /
VENDOR: http://mcrypt.sourceforge.net/ packaged for CSW by Alex Moore
PSTAMP: thor20080221185638
INSTDATE: Jul 11 2011 17:30
FILES: 103 installed pathnames
3 shared pathnames
4 directories
63 executables
1193 blocks used (approx)Re: nsca/mcrypt problem on Solaris 10
Note that this was occurred when compiling ncsa & send_ncsa from source.
This problem can be skipped by installed the CSW/Blastwave packages:
nsca-2.7.2,REV=2009.04.26-SunOS5.8-i386-CSW.pkg.gz
nsca-2.7.2,REV=2009.04.26-SunOS5.8-sparc-CSW.pkg.gz
send_nsca-2.7.2,REV=2009.04.26-SunOS5.8-i386-CSW.pkg.gz
send_nsca-2.7.2,REV=2009.04.26-SunOS5.8-sparc-CSW.pkg.gz
