I am receiving an error when trying to backup or upgrade my current Nagios XI Version 2012R2.5.
The error during an upgrade is...
Error 130 at line 5: Incorrect file format 'nagios_contactnotificationmethods' Upgrade from mysql-upgrade-2.0.0.sql filed at ./upgradedb line 106.
During a backup the error is similar.
I have tried several repair suggestions on the forum with zero success.
Thoughts or suggestions?
Joe
Error 130 while backing up or attempting to upgrade
[email protected]
Re: Error 130 while backing up or attempting to upgrade
You most likely have a damaged db. Try the repair scripts first:
If you continue to have problems, force a repair of the affected table with:
/usr/local/nagiosxi/scripts/repairmysql.sh nagios
/usr/local/nagiosxi/scripts/repairmysql.sh nagiosqlCode: Select all
echo "use nagios;repair table nagios_contactnotificationmethods use_frm;" | mysql -pnagiosxiFormer Nagios employee
