Nagios CCM user management
silvant
Post by silvant »
Is it possible to have the same users for CCM and NAGIOS XI ? We are using the trial version of Nagios XI and one of the features that we like to use is the Multi-Tenancy.
We have Multi-Tenancy in NAGIOS XI and in fact in the same instance we can have serveral users with its own envrionment of hosts/groups.
However the same is not true in CCM. If an user has priviliges to CCM he will have access to all existant infrastructure available in Nagios. Is there any step missing from configuration point of view or this "works as designed" ?
Regards
Nuno Silva
abrist
Red Shirt
Re: Nagios CCM user management
Post by abrist »
First, this is an XI question, so I will move it to the proper sub forum.
On to your question:
This is working as intended. Any use that is given access to the CCM will have access to the entire config. There would be little point otherwise. Standard users already have limited reconfigure access to their allowed objects under the object details page --> reconfigure.
