In NagioxXI 2014 R1.0 Nagvis 1.7.10 is included, but latest Nagvis is 1.8.B3. Can i upgrade Nagvis independent of NagiosXI 2014,
or do i have to wait for Nagvis being upgraded in an future NagiosXI release ?
thanks,
Peter Calum
TDC Denmark
Upgrading Nagvis
sreinhardt
- -fno-stack-protector
Re: Upgrading Nagvis
You can try, but we do not endorse or support the upgrade, so ideally no you should not separately update it. We have been looking into the changes needed to make the switch, but it is not a high priority at the moment. Is there something specifically that you are looking for that the upgrade provides?
Edit: I should have mentioned that our trials have shown that manual alterations are needed with the upgrade, so it likely will not work out of the box either.
Thank you for answering..
I have no special needs now for an upgrade, so i'll wait and follow the normal XI updates.
thanks,
Peter Calum
TDC, Denmark
thanks,
Peter Calum
TDC, Denmark
Peter Calum
sreinhardt
Sounds great, thanks for understanding!
