Need client plugins for ssh on RHEL4
Setting up an older RHEL 4 machine. Using ssh and NOT NRPE. I am able to successfully run /usr/local/nagios/libexec/check_by_ssh -H remoteip -C uptime. However when I try and run check _disk, the command is not found. And it is not present on the client. I need to find a tarball with a complete install of the ssh commands that is compatible with RHEL4.
sreinhardt
- -fno-stack-protector
Re: Need client plugins for ssh on RHEL4
What have you built or installed on the RHEL 4 system so far? As far as I know, if you wanted, the current nagios plugins should still build on RHEL4, but I have not tested this.
