Config Error - When adding or removing host
vicnanio
Post by vicnanio »
I am getting the following error on my NagiosXI server, when I try to add a new host and apply the configuration:
Error: Could not find any hostgroup matching 'Wireless' (config file '/usr/local/nagios/etc/hosts/3AB-AP225-A300 B.B..cfg', starting on line 14)
I ran a config check and got the following:
etc]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N480S.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-AP105-N621.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/challenger.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S330F.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/benthos.academic.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Pollux.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2C-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-AP105-S705.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SN-AP105-B208.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/slink.admeta.local.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Soto BB2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5S-AP105-S505C.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SN-AP105-B250.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/robot.adldap.local.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5S-AP105-S507.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10N-AP105-N1065.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B215.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-AP105-A715.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-AP225-N351.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B116.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4C-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A309.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-AP105-B320.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-AP105-B306.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SLB-AP105-ENTRY.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-AP105-A453.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B118.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N400.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-AP105-A700.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SN-AP105-B214.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8S-AP105-S824.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B400C.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B447.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/time.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A300.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5N-AP105-N517.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S380F.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N401S.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-AP105-A627.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Shelly BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B401.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B113B.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Yoko BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/WILLOW-AP105-HWY.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1C-AP105-C100.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-AP105-A701H.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Eddie BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B104.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-AP105-S625.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10N-AP105-N1042.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-AP225-N364.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/bopeep.admeta.local.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/TestBB - lemon.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-AP105-S700.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5N-AP105-N514.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-AP105-S990F.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-AP105-B301.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3C-AP105-C320.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-AP105-A415.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8N-AP105-N853.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S350HWY.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N480N.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10N-AP105-N1009.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4C-AP105-C414.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8N-AP105-N811.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B114B.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/lucia.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-AP105-A410.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B112A.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4S-AP105-S426.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/WILLOW-AP105-W140.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Diego BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-AP105-B300.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9N-AP105-N906.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-AP105-S910.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-AP105-N706.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S370.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2C-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-AP105-S701J.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1C-AP105-C142.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-AP105-N703.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/sarge.admeta.local.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3C-AP105-C340.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/atlantis.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/uhdgateway.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-A105-N716.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SLB-AP105-202.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S320E.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/WILLOW-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N410.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-AP105-S611.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Boba.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/172.17.31.12.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-Coffeehouse.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B140.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-AP105-N613.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SN-AP105-B331.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B117.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2C-AP105-C226.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3C-AP105-C300.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3C-SW3.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A309 Back.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SN-AP105-B350.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-AP105-A601.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B143.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2S-AP105-S280J.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-AP105-A701C.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A301.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SLB-AP105-201.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-AP105-A401.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-AP225-N330E.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-AP105-S647.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8S-AP105-S816.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10S-AP105-S1054.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9N-AP105-N938.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SN-AP105-B425.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-AP105-N637.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Ellie BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-AP105-N735.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B150.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B478.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-AP105-S701.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9N-AP105-N916.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10S-AP105-S1041.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-AP105-A480.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-AP105-S970H.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B410K.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SN-AP105-B471.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Carl BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Idp Shib Org.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8N-AP105-N832.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2C-AP105-C212.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-AP105-A606.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/mothra.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5N-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5S-AP105-S501.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2N-AP105-N265.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8S-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-AP105-A710.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1N-AP105-S111.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-AP105-A705.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SN-AP105-B314.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Nadia BB2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-AP105-N604.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-AP105-S681.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/acamar.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-AP105-B304.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A300 W.O..cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8N-AP105-N804.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2S-AP105-S204L.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SN-AP105-B343.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Testcyber.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-AP105-S745.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Uhdgateway.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-AP225-N315.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5N-AP105-N508.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5S-AP105-S506.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4S-AP65-S441.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/scud.adldap.local.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2N-AP105-N250C.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SLB-AP105-305.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-AP105-N732.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2NW-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1N-AP105-N110.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/172.17.1.36.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Lenny BB2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SN-AP105-B489.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-AP105-S970.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SN-AP105-B435.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B113A.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4C-AP105-C400.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2C-AP105-C222.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B114A.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6N-AP105-N630.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B200C.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10S-AP105-S1077.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/WILLOW-AP105-W100.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2S-AP105-S269.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/F5 Code 10 Primary.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8S-AP105-S830.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SLB-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10S-AP105-S1015.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-AP105-N729.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/shibb.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B110.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SS-AP105-B325.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N442.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8S-AP105-S812.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B419.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4AB-AP105-A429.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-AP105-A615.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SN-AP105-B240.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SS-AP105-B400A.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SN-AP105-B219.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10N-AP105-N1098.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1C-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3C-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-AP105-S910M.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/columbia.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2N-AP105-N215.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/hamm.adldap.local.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7S-AP105-S728.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-AP105-A609.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B213.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/11N-AP105-S1100.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S350E.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Egbert BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-AP225-N320L.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A350.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B200B.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B108.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1N-AP105-N118.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B112B.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-AP105-S696.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2S-AP105-S204M.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SN-AP105-B119.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3N-AP225-N320U.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/endeavour.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3SN-AP105-B332.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3C-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7AB-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4C-AP105-C420.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N401N.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3S-AP225-S370M.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9N-AP105-N933.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B106.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/DT-GW3.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6AB-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Scrat BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4SN-AP105-B441.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B200A.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/6S-AP105-S605.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A311.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/www.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/7N-AP105-N725.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2S-AP105-S204.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Frank BB.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4S-AP105-S412.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/8N-AP105-N834.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Testwww.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2N-AP105-N294.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9S-AP105-S950.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1C-AP105-C106.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4N-AP105-N401D.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10N-AP105-N1055.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B206.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3NW-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3NW-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4S-AP105-S405.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/3AB-AP225-A300 B.B..cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/4C-AP105-C442.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1N-AP105-N118A.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/9N-AP105-N944.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/2SS-AP105-B201.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5N-AP105-N503.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1N-AP105-N116.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/1SS-AP105-B101.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/5S-AP105-S503.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N480S.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-AP105-N621.cfg'...
Processing object config file '/usr/local/nagios/etc/services/challenger.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S330F.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Pollux.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2C-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-AP105-S705.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SN-AP105-B208.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A301 .cfg'...
Processing object config file '/usr/local/nagios/etc/services/slink.admeta.local.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Soto BB2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5S-AP105-S505C.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SN-AP105-B250.cfg'...
Processing object config file '/usr/local/nagios/etc/services/robot.adldap.local.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5S-AP105-S507.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10N-AP105-N1065.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B215.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-AP105-A715.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-AP225-N351.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B116.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4C-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A309.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-AP105-B320.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-AP105-B306.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SLB-AP105-ENTRY.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-AP105-A453.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B118.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N400.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-AP105-A700.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SN-AP105-B214.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8S-AP105-S824.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B400C.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B447.cfg'...
Processing object config file '/usr/local/nagios/etc/services/time.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A300.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5N-AP105-N517.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S380F.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N401S.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-AP105-A627.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Shelly BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B401.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B113B.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Yoko BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/WILLOW-AP105-HWY.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1C-AP105-C100.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-AP105-A701H.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Eddie BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B104.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-AP105-S625.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10N-AP105-N1042.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-AP225-N364.cfg'...
Processing object config file '/usr/local/nagios/etc/services/bopeep.admeta.local.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-AP105-S700.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5N-AP105-N514.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S990F.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-AP105-B301.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3C-AP105-C320.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-AP105-A415.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8N-AP105-N853.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S350HWY.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N480N.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10N-AP105-N1009.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4C-AP105-C414.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8N-AP105-N811.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B114B.cfg'...
Processing object config file '/usr/local/nagios/etc/services/lucia.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-AP105-A410.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B112A.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4S-AP105-S426.cfg'...
Processing object config file '/usr/local/nagios/etc/services/WILLOW-AP105-W140.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Diego BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-AP105-B300.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9N-AP105-N906.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S910.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-AP105-N706.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S370.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2C-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-AP105-S701J.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1C-AP105-C142.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-AP105-N703.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sarge.admeta.local.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3C-AP105-C340.cfg'...
Processing object config file '/usr/local/nagios/etc/services/atlantis.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/uhdgateway.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-A105-N716.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SLB-AP105-202.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S320E.cfg'...
Processing object config file '/usr/local/nagios/etc/services/WILLOW-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N410.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-AP105-S611.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Boba.cfg'...
Processing object config file '/usr/local/nagios/etc/services/172.17.31.12.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-Coffeehouse.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B140.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Lemon - TestBBNG.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-AP105-N613.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SN-AP105-B331.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B117.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2C-AP105-C226.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3C-AP105-C300.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3C-SW3.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A309 Back.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SN-AP105-B350.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-AP105-A601.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B143.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2S-AP105-S280J.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-AP105-A701C.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A301.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SLB-AP105-201.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-AP105-A401.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-AP225-N330E.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-AP105-S647.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8S-AP105-S816.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10S-AP105-S1054.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9N-AP105-N938.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SN-AP105-B425.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-AP105-N637.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Ellie BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-AP105-N735.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B150.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B478.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-AP105-S701.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9N-AP105-N916.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10S-AP105-S1041.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-AP105-A480.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S970H.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B410K.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SN-AP105-B471.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Carl BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Idp Shib Org.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8N-AP105-N832.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2C-AP105-C212.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-AP105-A606.cfg'...
Processing object config file '/usr/local/nagios/etc/services/mothra.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5N-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5S-AP105-S501.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2N-AP105-N265.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8S-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-AP105-A710.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1N-AP105-S111.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-AP105-A705.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SN-AP105-B314.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Nadia BB2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-AP105-N604.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-AP105-S681.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/acamar.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-AP105-B304.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A300 W.O..cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8N-AP105-N804.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2S-AP105-S204L.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SN-AP105-B343.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Testcyber.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-AP105-S745.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-AP225-N315.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5N-AP105-N508.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5S-AP105-S506.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4S-AP65-S441.cfg'...
Processing object config file '/usr/local/nagios/etc/services/scud.adldap.local.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2N-AP105-N250C.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SLB-AP105-305.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-AP105-N732.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2NW-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1N-AP105-N110.cfg'...
Processing object config file '/usr/local/nagios/etc/services/172.17.1.36.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Lenny BB2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SN-AP105-B489.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S970.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SN-AP105-B435.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B113A.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4C-AP105-C400.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2C-AP105-C222.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B114A.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6N-AP105-N630.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B200C.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10S-AP105-S1077.cfg'...
Processing object config file '/usr/local/nagios/etc/services/WILLOW-AP105-W100.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2S-AP105-S269.cfg'...
Processing object config file '/usr/local/nagios/etc/services/F5 Code 10 Primary.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8S-AP105-S830.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SLB-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10S-AP105-S1015.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-AP105-N729.cfg'...
Processing object config file '/usr/local/nagios/etc/services/shibb.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B110.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SS-AP105-B325.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N442.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8S-AP105-S812.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B419.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4AB-AP105-A429.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4S-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-AP105-A615.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SN-AP105-B240.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SS-AP105-B400A.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SN-AP105-B219.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10N-AP105-N1098.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1C-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3C-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S910M.cfg'...
Processing object config file '/usr/local/nagios/etc/services/columbia.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2N-AP105-N215.cfg'...
Processing object config file '/usr/local/nagios/etc/services/hamm.adldap.local.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7S-AP105-S728.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-AP105-A609.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B213.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S350E.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Egbert BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-AP225-N320L.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A350.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B200B.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B108.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1N-AP105-N118.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B112B.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-AP105-S696.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2S-AP105-S204M.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SN-AP105-B119.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3N-AP225-N320U.cfg'...
Processing object config file '/usr/local/nagios/etc/services/endeavour.uhd.campus.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3SN-AP105-B332.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3C-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7AB-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4C-AP105-C420.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N401N.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3S-AP225-S370M.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9N-AP105-N933.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B106.cfg'...
Processing object config file '/usr/local/nagios/etc/services/DT-GW3.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6AB-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Scrat BB.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4SN-AP105-B441.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B200A.cfg'...
Processing object config file '/usr/local/nagios/etc/services/6S-AP105-S605.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A311.cfg'...
Processing object config file '/usr/local/nagios/etc/services/www.uhd.edu.cfg'...
Processing object config file '/usr/local/nagios/etc/services/7N-AP105-N725.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2S-AP105-S204.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A300 .cfg'...
Processing object config file '/usr/local/nagios/etc/services/4S-AP105-S412.cfg'...
Processing object config file '/usr/local/nagios/etc/services/8N-AP105-N834.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Testwww.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2N-AP105-N294.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S950.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1C-AP105-C106.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4N-AP105-N401D.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10N-AP105-N1055.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B206.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3NW-SW1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3NW-SW2.cfg'...
Processing object config file '/usr/local/nagios/etc/services/4S-AP105-S405.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Frank.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SN-SW.cfg'...
Processing object config file '/usr/local/nagios/etc/services/3AB-AP225-A300 B.B..cfg'...
Processing object config file '/usr/local/nagios/etc/services/4C-AP105-C442.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1N-AP105-N118A.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9N-AP105-N944.cfg'...
Processing object config file '/usr/local/nagios/etc/services/2SS-AP105-B201.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5N-AP105-N503.cfg'...
Processing object config file '/usr/local/nagios/etc/services/1N-AP105-N116.cfg'...
Processing object config file '/usr/local/nagios/etc/services/9S-AP105-S970 .cfg'...
Processing object config file '/usr/local/nagios/etc/services/1SS-AP105-B101.cfg'...
Processing object config file '/usr/local/nagios/etc/services/5S-AP105-S503.cfg'...
Warning: Duplicate definition found for service 'Ping' on host '9S-AP105-S970' (config file '/usr/local/nagios/etc/services/9S-AP105-S970.cfg', starting on line 14)
Warning: Duplicate definition found for service 'Ping' on host '3AB-AP225-A300' (config file '/usr/local/nagios/etc/services/3AB-AP225-A300.cfg', starting on line 14)
Warning: Duplicate definition found for service 'Ping' on host '3AB-AP225-A301' (config file '/usr/local/nagios/etc/services/3AB-AP225-A301 .cfg', starting on line 14)
Checking services...
Warning: Service 'Ping' on host '5S-AP105-S505C' has no default contacts or contactgroups defined!
        Checked 761 services.
Checking hosts...
Warning: Host '5S-AP105-S505C' has no default contacts or contactgroups defined!
        Checked 294 hosts.
Checking host groups...
        Checked 23 host groups.
Checking service groups...
        Checked 1 service groups.
Checking contacts...
Warning: Service recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify critical and/or warning options as well
        Checked 15 contacts.
Checking contact groups...
        Checked 4 contact groups.
Checking service escalations...
Checking service dependencies...
        Checked 0 service dependencies.
Checking host escalations...
        Checked 0 host escalations.
Checking host dependencies...
        Checked 0 host dependencies.
Checking commands...
        Checked 109 commands.
Checking time periods...
        Checked 21 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 3
Total Errors:   0
Re: Config Error - When adding or removing host
Do you have a hostgroup, named 'Wireless'? Did you check what you have on line 14 in '/usr/local/nagios/etc/hosts/3AB-AP225-A300 B.B..cfg'? Can you run the Write Conifg Tool and show us the output?
CCM->Tools->Write Config Files->Write (show the output)
CCM->Tools->Write Config Files->Verify (show the output)
vicnanio
Post by vicnanio »
Here is the output:
[quoteWrite host configurations ...
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!][/quote]
Nagios Core 3.5.0
License: GPL
      1 ###############################################################################
      2 #
      3 # Host configuration file
      4 #
      5 # Created by: Nagios QL Version 3.0.3
      6 # Date:       2014-03-17 16:28:32
      7 # Version:    Nagios 3.x config file
      8 #
      9 # --- DO NOT EDIT THIS FILE BY HAND ---
     10 # Nagios QL will overwite all manual settings during the next update
     11 #
     12 ###############################################################################
     13
     14 define host {
     15         host_name                       3AB-AP225-A300 B.B.
     16         use                             xiwizard_switch_host
     17         address                         172.17.60.131
     18         hostgroups                      Wireless
     19         max_check_attempts              5
     20         check_interval                  5
     21         retry_interval                  1
     22         check_period                    xi_timeperiod_24x7
     23         contacts                        montelongol,reynaf
     24         notification_interval           60
     25         notification_period             xi_timeperiod_24x7
     28         _xiwizard                       switch
     29         register                        1
     30         }
     31
     32 ###############################################################################
     33 #
     34 # Host configuration file
     35 #
     36 # END OF FILE
     37 #
     38 ###############################################################################
Mod Note: Use code tags when posting long output
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Error on verification:
Config line:
I think you need to be sure that hostgroup still exists and is named the same. You can look in both CCM hostgroups and /usr/local/nagios/etc/hostgroups.cfg to check those out.
vicnanio
Post by vicnanio »
Everything was good until one of our admins deleted the "wireless" group and after that no one was able to add or delete anything.
      2 #
      3 # Hostgroup configuration file
      4 #
      6 # Date:       2014-06-02 15:55:54
      8 #
     11 #
     13
     14 define hostgroup {
     15         hostgroup_name                          Academic Access Switches
     16         alias                                   Academic Access Switches
     17         }
     18
     19 define hostgroup {
     20         hostgroup_name                          ACADEMIC domain controllers
     21         alias                                   ACADEMIC domain controllers
     22         }
     23
     24 define hostgroup {
     25         hostgroup_name                          Academic Wireless APs
     26         alias                                   Academic Wireless APs
     27         }
     28
     29 define hostgroup {
     30         hostgroup_name                          ADLDAP.LOCAL domain controllers
     31         alias                                   ADLDAP.LOCAL domain controllers
     32         }
     33
     34 define hostgroup {
     35         hostgroup_name                          ADMETA.LOCAL domain controllers
     36         alias                                   ADMETA.LOCAL domain controllers
     37         }
     38
     39 define hostgroup {
     40         hostgroup_name                          Blackboard-linux-servers
     41         alias                                   Blackboard Environments
     42         hostgroup_members                       Blackboard-linux-servers-Bb,Blackboard-linux-servers-Bb2,Blackboard-linux-servers-TestBBNG
     43         }
     44
     45 define hostgroup {
     46         hostgroup_name                          Blackboard-linux-servers-Bb
     47         alias                                   Bb Prod
     48         members                                 Carl BB,Diego BB,Egbert BB,Ellie BB,Frank BB,Scrat BB,Shelly BB,Yoko BB
     49         notes_url                               https://bb.uhd.edu
     50         }
     51
     52 define hostgroup {
     53         hostgroup_name                          Blackboard-linux-servers-Bb2
     54         alias                                   Bb2 Prod
     55         members                                 Lenny BB2,Nadia BB2,Soto BB2
     56         notes_url                               https://bb2.uhd.edu
     57         }
     58
     59 define hostgroup {
     60         hostgroup_name                          Blackboard-linux-servers-TestBBNG
     61         alias                                   TestBBNG
     62         members                                 TestBB - lemon.uhd.edu
     63         notes_url                               https://testbbng.uhd.edu
     64         }
     65
     66 define hostgroup {
     67         hostgroup_name                          Commerce Access Switches
     68         alias                                   Commerce Access Switches
     69         }
     70
     71 define hostgroup {
     72         hostgroup_name                          Commerce Wireless APs
     73         alias                                   Commerce Wireless APs
     74         members                                 1C-AP105-C100,1C-AP105-C106,1C-AP105-C142,2C-AP105-C212,2C-AP105-C222,2C-AP105-C226,3C-AP105-C300,3C-AP105-C320,3C-A        P105-C340,4C-AP105-C400,4C-AP105-C414,4C-AP105-C420,4C-AP105-C442
     75         }
     76
     77 define hostgroup {
     78         hostgroup_name                          Exchange Servers
     79         alias                                   Exchange Servers
     80         }
     81
     82 define hostgroup {
     83         hostgroup_name                          linux-servers
     84         alias                                   Linux Servers
     85         members                                 localhost
     86         }
     87
     88 define hostgroup {
     89         hostgroup_name                          Main Access Switches
     90         alias                                   Main Access Switches
     91         members                                 10N-SW,10S-SW
     92         }
     93
     94 define hostgroup {
     95         hostgroup_name                          Main Wireless APs
     96         alias                                   Main Wireless APs
     97         members                                 10N-AP105-N1009,10N-AP105-N1042,10N-AP105-N1055,10N-AP105-N1065,10N-AP105-N1098,10S-AP105-S1015,10S-AP105-S1041,10S-        AP105-S1054,10S-AP105-S1077,11N-AP105-S1100,1N-AP105-N110,1N-AP105-N116,1N-AP105-N118,1N-AP105-N118A,1N-AP105-S111,2N-AP105-N215,2N-AP105-N250C,2N-AP105-N265,2N-AP1        05-N294,2S-AP105-S204,2S-AP105-S204L,2S-AP105-S204M,2S-AP105-S269,2S-AP105-S280J,3N-AP225-N330E,3N-AP225-N351,3S-AP225-S350HWY,4N-AP105-N400,4N-AP105-N401D,4N-AP105        -N401N,4N-AP105-N401S,4N-AP105-N410,4N-AP105-N442,4N-AP105-N480N,4N-AP105-N480S,4S-AP105-S405,4S-AP105-S412,4S-AP105-S426,4S-AP65-S441,5N-AP105-N503,5N-AP105-N508,5        N-AP105-N514,5N-AP105-N517,5S-AP105-S501,5S-AP105-S503,5S-AP105-S505C,5S-AP105-S506,5S-AP105-S507,6N-AP105-N604,6N-AP105-N613,6N-AP105-N621,6N-AP105-N630,6N-AP105-N        637,6S-AP105-S605,6S-AP105-S611,6S-AP105-S625,6S-AP105-S647,6S-AP105-S681,6S-AP105-S696,7N-A105-N716,7N-AP105-N703,7N-AP105-N706,7N-AP105-N725,7N-AP105-N729,7N-AP10        5-N732,7N-AP105-N735,7S-AP105-S700,7S-AP105-S701,7S-AP105-S701J,7S-AP105-S705,7S-AP105-S728,7S-AP105-S745,8N-AP105-N804,8N-AP105-N811,8N-AP105-N832,8N-AP105-N834,8N        -AP105-N853,8S-AP105-S812,8S-AP105-S816,8S-AP105-S824,8S-AP105-S830,9N-AP105-N906,9N-AP105-N916,9N-AP105-N933,9N-AP105-N938,9N-AP105-N944,9S-AP105-S910,9S-AP105-S91        0M,9S-AP105-S950,9S-AP105-S970,9S-AP105-S970H,9S-AP105-S990F
     98         }
     99
    100 define hostgroup {
    101         hostgroup_name                          Sharepoint
    102         alias                                   Sharepoint
    103         }
    104
    105 define hostgroup {
    106         hostgroup_name                          Shea Access Switches
    107         alias                                   Shea Access Switches
    108         }
    109
    110 define hostgroup {
    111         hostgroup_name                          SLB Wireless APs
    112         alias                                   SLB Wireless APs
    113         members                                 SLB-AP105-201,SLB-AP105-202,SLB-AP105-305,SLB-AP105-ENTRY
    114         }
    115
    116 define hostgroup {
    117         hostgroup_name                          UHD domain controllers
    118         alias                                   UHD domain controllers    119         }
    120
    121 define hostgroup {
    122         hostgroup_name                          UHD-NW Access Switches
    123         alias                                   UHD-NW Access Switches
    124         }
    125
    126 define hostgroup {
    127         hostgroup_name                          Willow Wireless APs
    128         alias                                   Willow Wireless APs
    129         members                                 WILLOW-AP105-HWY,WILLOW-AP105-W100,WILLOW-AP105-W140
    130         }
    131
    132 define hostgroup {
    133         hostgroup_name                          Windows Servers
    134         alias                                   Windows Servers
    135         }
    136
    137 ###############################################################################
    138 #
    139 # Timeperiod configuration file
    140 #
    141 # END OF FILE
    142 #    143 ###############################################################################]
Post by slansing »
So you either need to add the host-group back in, or remove all dependent mentions of it in your hosts/templates, then you should be able to apply config.
vicnanio
Post by vicnanio »
Where would we remove all those references to "Wireless"? All of us are new to NagiosXI and would appreciate some guidance on how to clear things up on our configuration. I can't find any references to "Wireless" in the Hostgroups, Hosts, or services via the web admin page.
Let's start with looking at the error:
Go to the Core Config Manager->Hosts->locate the "3AB-AP225-A300 B.B" host and click on it, then click on "Manage Hostgroups" button (under the "Common Settings" tab)
Remove "Wireless" from the "Assigned", close, and save. Don't apply configuration yet as you may have more hosts that this hostgroup has been assigned to. Run the "Write Config Tool" to check for more errors:
If you find more errors, go back to the CCM and fix them. Run the "Write Config Tool" as many times as you need to.
Hopefully, you don't have way too many hosts that "Wireless" hostgroup is assigned to. It may be easier just to add back the "Wireless" hostgroup.
vicnanio
Post by vicnanio »
I did what you asked and I could not find a "AB-AP225-A300 B.B". I am able to find that hostgroup via command line. any suggestions?
Run the following command and show us the output:
ls -la /usr/local/nagios/etc/hosts | grep 3AB-AP225-A300
So you didn't find this host in the CCM->Hosts?
