This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
tecnalb
Posts: 133 Joined: Tue May 03, 2011 12:53 pm
Post
by tecnalb » Mon Jun 02, 2014 4:36 pm
After update to 2014, all of my mrtg was busted, due to the script that decided to relocate config data. This placed various switch data together under a single cfg. I have that figured out, and I'm manually fixing it. However, this has not fixed my graphing for ping times and RTA.
Digging further the red files for those two metric have not been updated since the upgrade took place. Other metrics show a current timestamp.
[root@nagios x.x.x.1]# ls -l
total 15964
-rwxrwxr-x 1 nagios nagios 768232 Jun 2 17:53 Adaptive-Security-Appliance-outside-interface_Bandwidth.rrd
-rw-rw-rw- 1 nagios nagios 3145 Jun 2 17:53 Adaptive-Security-Appliance-outside-interface_Bandwidth.xml
-rwxrwxr-x 1 nagios nagios 768232 Jun 2 13:52 _HOST_.rrd
-rw-rw-rw- 1 nagios nagios 4024 Jun 2 17:55 _HOST_.xml
-rwxrwxr-x 1 nagios nagios 768232 Jun 2 13:50 Ping.rrd
-rw-rw-rw- 1 nagios nagios 4135 Jun 2 17:53 Ping.xml
tecnalb
Post
by tecnalb » Tue Jun 03, 2014 10:11 am
I have looked thru some logs, and I see no errors.
The advanced info box on the Ping checks do show data. So this is a graphing issue. I have 0 hosts with any new data. The graphs stop at a time prior to my upgrade yesterday.
Mod note: Please edit you previous post to add information if you are the last poster, double posting will reset the age of your last post on the list. Also, please use CODE wraps when you add output from commands, or the CLI to your reply so it makes it easier to read.
abrist
Red Shirt
Posts: 8334 Joined: Thu Nov 15, 2012 1:20 pm
Post
by abrist » Tue Jun 03, 2014 12:33 pm
tecnalb wrote: I have looked thru some logs, and I see no errors.
I don't know which logs you looked at, but we can usually get some information from the perfdata/npcd logs:
tail -25 /usr/local/nagios/var/perdata.log
tail -25 /usr/local/nagios/var/npcd.log
Come to the
Dark Side .
tecnalb
Post
by tecnalb » Tue Jun 03, 2014 12:49 pm
perfdata logs have no current entries within.... last entry 2014-04-06
npcd log
[06-03-2014 13:43:31] NPCD: Processing file '1401817392.perfdata.service'
[06-03-2014 13:43:31] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:43:46] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:43:46] NPCD: DEBUG: load 1.810000/10.000000
[06-03-2014 13:43:46] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:43:46] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:43:46] NPCD: ThreadCounter 0/5 File is 1401817407.perfdata.host
[06-03-2014 13:43:46] NPCD: Regular File: 1401817407.perfdata.host
[06-03-2014 13:43:46] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:43:46] NPCD: ThreadCounter 1/5 File is 1401817407.perfdata.service
[06-03-2014 13:43:46] NPCD: Regular File: 1401817407.perfdata.service
[06-03-2014 13:43:46] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:43:46] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:43:46] NPCD: Processing file 1401817407.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817407.perfdata.host
[06-03-2014 13:43:46] NPCD: Processing file '1401817407.perfdata.host'
[06-03-2014 13:43:46] NPCD: Processing file 1401817407.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817407.perfdata.service
[06-03-2014 13:43:46] NPCD: Processing file '1401817407.perfdata.service'
[06-03-2014 13:43:46] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:44:01] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:44:01] NPCD: DEBUG: load 1.410000/10.000000
[06-03-2014 13:44:01] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:44:01] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:44:01] NPCD: ThreadCounter 0/5 File is 1401817422.perfdata.host
[06-03-2014 13:44:01] NPCD: Regular File: 1401817422.perfdata.host
[06-03-2014 13:44:01] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:44:01] NPCD: ThreadCounter 1/5 File is 1401817422.perfdata.service
[06-03-2014 13:44:01] NPCD: Regular File: 1401817422.perfdata.service
[06-03-2014 13:44:01] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:44:01] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:44:01] NPCD: Processing file 1401817422.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817422.perfdata.host
[06-03-2014 13:44:01] NPCD: Processing file '1401817422.perfdata.host'
[06-03-2014 13:44:01] NPCD: Processing file 1401817422.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817422.perfdata.service
[06-03-2014 13:44:01] NPCD: Processing file '1401817422.perfdata.service'
[06-03-2014 13:44:02] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:44:17] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:44:17] NPCD: DEBUG: load 2.060000/10.000000
[06-03-2014 13:44:17] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:44:17] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:44:17] NPCD: ThreadCounter 0/5 File is 1401817437.perfdata.host
[06-03-2014 13:44:17] NPCD: Regular File: 1401817437.perfdata.host
[06-03-2014 13:44:17] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:44:17] NPCD: ThreadCounter 1/5 File is 1401817437.perfdata.service
[06-03-2014 13:44:17] NPCD: Regular File: 1401817437.perfdata.service
[06-03-2014 13:44:17] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:44:17] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:44:17] NPCD: Processing file 1401817437.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817437.perfdata.host
[06-03-2014 13:44:17] NPCD: Processing file '1401817437.perfdata.host'
[06-03-2014 13:44:17] NPCD: Processing file 1401817437.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817437.perfdata.service
[06-03-2014 13:44:17] NPCD: Processing file '1401817437.perfdata.service'
[06-03-2014 13:44:17] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:44:32] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:44:32] NPCD: DEBUG: load 1.600000/10.000000
[06-03-2014 13:44:32] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:44:32] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:44:32] NPCD: ThreadCounter 0/5 File is 1401817452.perfdata.host
[06-03-2014 13:44:32] NPCD: Regular File: 1401817452.perfdata.host
[06-03-2014 13:44:32] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:44:32] NPCD: ThreadCounter 1/5 File is 1401817452.perfdata.service
[06-03-2014 13:44:32] NPCD: Regular File: 1401817452.perfdata.service
[06-03-2014 13:44:32] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:44:32] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:44:32] NPCD: Processing file 1401817452.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817452.perfdata.host
[06-03-2014 13:44:32] NPCD: Processing file '1401817452.perfdata.host'
[06-03-2014 13:44:32] NPCD: Processing file 1401817452.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817452.perfdata.service
[06-03-2014 13:44:32] NPCD: Processing file '1401817452.perfdata.service'
[06-03-2014 13:44:32] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:44:47] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:44:47] NPCD: DEBUG: load 1.210000/10.000000
[06-03-2014 13:44:47] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:44:47] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:44:47] NPCD: ThreadCounter 0/5 File is 1401817467.perfdata.host
[06-03-2014 13:44:47] NPCD: Regular File: 1401817467.perfdata.host
[06-03-2014 13:44:47] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:44:47] NPCD: ThreadCounter 1/5 File is 1401817467.perfdata.service
[06-03-2014 13:44:47] NPCD: Regular File: 1401817467.perfdata.service
[06-03-2014 13:44:47] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:44:47] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:44:47] NPCD: Processing file 1401817467.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817467.perfdata.host
[06-03-2014 13:44:47] NPCD: Processing file '1401817467.perfdata.host'
[06-03-2014 13:44:47] NPCD: Processing file 1401817467.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817467.perfdata.service
[06-03-2014 13:44:47] NPCD: Processing file '1401817467.perfdata.service'
[06-03-2014 13:44:47] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:45:02] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:45:02] NPCD: DEBUG: load 1.820000/10.000000
[06-03-2014 13:45:02] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:45:02] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:45:02] NPCD: ThreadCounter 0/5 File is 1401817482.perfdata.host
[06-03-2014 13:45:02] NPCD: Regular File: 1401817482.perfdata.host
[06-03-2014 13:45:02] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:45:02] NPCD: ThreadCounter 1/5 File is 1401817482.perfdata.service
[06-03-2014 13:45:02] NPCD: Regular File: 1401817482.perfdata.service
[06-03-2014 13:45:02] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:45:02] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:45:02] NPCD: Processing file 1401817482.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817482.perfdata.host
[06-03-2014 13:45:02] NPCD: Processing file '1401817482.perfdata.host'
[06-03-2014 13:45:02] NPCD: Processing file 1401817482.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817482.perfdata.service
[06-03-2014 13:45:02] NPCD: Processing file '1401817482.perfdata.service'
[06-03-2014 13:45:02] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:45:17] NPCD: Found 6 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:45:17] NPCD: DEBUG: load 1.550000/10.000000
[06-03-2014 13:45:17] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:45:17] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:45:17] NPCD: ThreadCounter 0/5 File is 1401817497.perfdata.host
[06-03-2014 13:45:17] NPCD: Regular File: 1401817497.perfdata.host
[06-03-2014 13:45:17] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:45:17] NPCD: ThreadCounter 1/5 File is 1401817497.perfdata.service
[06-03-2014 13:45:17] NPCD: Regular File: 1401817497.perfdata.service
[06-03-2014 13:45:17] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:45:17] NPCD: ThreadCounter 2/5 File is 1401817512.perfdata.host
[06-03-2014 13:45:17] NPCD: Regular File: 1401817512.perfdata.host
[06-03-2014 13:45:17] NPCD: A thread was started on thread_counter = 2
[06-03-2014 13:45:17] NPCD: ThreadCounter 3/5 File is 1401817512.perfdata.service
[06-03-2014 13:45:17] NPCD: Regular File: 1401817512.perfdata.service
[06-03-2014 13:45:17] NPCD: A thread was started on thread_counter = 3
[06-03-2014 13:45:17] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[06-03-2014 13:45:17] NPCD: Processing file 1401817497.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817497.perfdata.host
[06-03-2014 13:45:17] NPCD: Processing file '1401817497.perfdata.host'
[06-03-2014 13:45:17] NPCD: Processing file 1401817497.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817497.perfdata.service
[06-03-2014 13:45:17] NPCD: Processing file '1401817497.perfdata.service'
[06-03-2014 13:45:17] NPCD: Processing file 1401817512.perfdata.host with ID 47688609204544 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817512.perfdata.host
[06-03-2014 13:45:17] NPCD: Processing file '1401817512.perfdata.host'
[06-03-2014 13:45:17] NPCD: Processing file 1401817512.perfdata.service with ID 47688619694400 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817512.perfdata.service
[06-03-2014 13:45:17] NPCD: Processing file '1401817512.perfdata.service'
[06-03-2014 13:45:17] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:45:32] NPCD: Found 2 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:45:32] NPCD: DEBUG: load 1.210000/10.000000
[06-03-2014 13:45:32] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:45:32] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:45:32] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:45:47] NPCD: Found 6 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:45:47] NPCD: DEBUG: load 0.940000/10.000000
[06-03-2014 13:45:47] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:45:47] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:45:47] NPCD: ThreadCounter 0/5 File is 1401817527.perfdata.host
[06-03-2014 13:45:47] NPCD: Regular File: 1401817527.perfdata.host
[06-03-2014 13:45:47] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:45:47] NPCD: ThreadCounter 1/5 File is 1401817527.perfdata.service
[06-03-2014 13:45:47] NPCD: Regular File: 1401817527.perfdata.service
[06-03-2014 13:45:47] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:45:47] NPCD: ThreadCounter 2/5 File is 1401817542.perfdata.host
[06-03-2014 13:45:47] NPCD: Regular File: 1401817542.perfdata.host
[06-03-2014 13:45:47] NPCD: A thread was started on thread_counter = 2
[06-03-2014 13:45:47] NPCD: ThreadCounter 3/5 File is 1401817542.perfdata.service
[06-03-2014 13:45:47] NPCD: Regular File: 1401817542.perfdata.service
[06-03-2014 13:45:47] NPCD: A thread was started on thread_counter = 3
[06-03-2014 13:45:47] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[06-03-2014 13:45:47] NPCD: Processing file 1401817527.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817527.perfdata.host
[06-03-2014 13:45:47] NPCD: Processing file '1401817527.perfdata.host'
[06-03-2014 13:45:47] NPCD: Processing file 1401817527.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817527.perfdata.service
[06-03-2014 13:45:47] NPCD: Processing file '1401817527.perfdata.service'
[06-03-2014 13:45:47] NPCD: Processing file 1401817542.perfdata.host with ID 47688609204544 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817542.perfdata.host
[06-03-2014 13:45:47] NPCD: Processing file '1401817542.perfdata.host'
[06-03-2014 13:45:47] NPCD: Processing file 1401817542.perfdata.service with ID 47688619694400 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817542.perfdata.service
[06-03-2014 13:45:47] NPCD: Processing file '1401817542.perfdata.service'
[06-03-2014 13:45:47] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:46:02] NPCD: Found 2 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:46:02] NPCD: DEBUG: load 1.370000/10.000000
[06-03-2014 13:46:02] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:46:02] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:46:02] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:46:17] NPCD: Found 6 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:46:17] NPCD: DEBUG: load 1.210000/10.000000
[06-03-2014 13:46:17] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:46:17] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:46:17] NPCD: ThreadCounter 0/5 File is 1401817557.perfdata.host
[06-03-2014 13:46:17] NPCD: Regular File: 1401817557.perfdata.host
[06-03-2014 13:46:17] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:46:17] NPCD: ThreadCounter 1/5 File is 1401817557.perfdata.service
[06-03-2014 13:46:17] NPCD: Regular File: 1401817557.perfdata.service
[06-03-2014 13:46:17] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:46:17] NPCD: ThreadCounter 2/5 File is 1401817572.perfdata.host
[06-03-2014 13:46:17] NPCD: Regular File: 1401817572.perfdata.host
[06-03-2014 13:46:17] NPCD: A thread was started on thread_counter = 2
[06-03-2014 13:46:17] NPCD: ThreadCounter 3/5 File is 1401817572.perfdata.service
[06-03-2014 13:46:17] NPCD: Regular File: 1401817572.perfdata.service
[06-03-2014 13:46:17] NPCD: A thread was started on thread_counter = 3
[06-03-2014 13:46:17] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[06-03-2014 13:46:17] NPCD: Processing file 1401817557.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817557.perfdata.host
[06-03-2014 13:46:17] NPCD: Processing file '1401817557.perfdata.host'
[06-03-2014 13:46:17] NPCD: Processing file 1401817557.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817557.perfdata.service
[06-03-2014 13:46:17] NPCD: Processing file 1401817572.perfdata.host with ID 47688609204544 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817572.perfdata.host
[06-03-2014 13:46:17] NPCD: Processing file 1401817572.perfdata.service with ID 47688619694400 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817572.perfdata.service
[06-03-2014 13:46:17] NPCD: Processing file '1401817557.perfdata.service'
[06-03-2014 13:46:17] NPCD: Processing file '1401817572.perfdata.host'
[06-03-2014 13:46:17] NPCD: Processing file '1401817572.perfdata.service'
[06-03-2014 13:46:17] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:46:32] NPCD: Found 2 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:46:32] NPCD: DEBUG: load 0.940000/10.000000
[06-03-2014 13:46:32] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:46:32] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:46:32] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:46:47] NPCD: Found 6 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:46:47] NPCD: DEBUG: load 0.730000/10.000000
[06-03-2014 13:46:47] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:46:47] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:46:47] NPCD: ThreadCounter 0/5 File is 1401817587.perfdata.host
[06-03-2014 13:46:47] NPCD: Regular File: 1401817587.perfdata.host
[06-03-2014 13:46:47] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:46:47] NPCD: ThreadCounter 1/5 File is 1401817587.perfdata.service
[06-03-2014 13:46:47] NPCD: Regular File: 1401817587.perfdata.service
[06-03-2014 13:46:47] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:46:47] NPCD: ThreadCounter 2/5 File is 1401817602.perfdata.host
[06-03-2014 13:46:47] NPCD: Regular File: 1401817602.perfdata.host
[06-03-2014 13:46:47] NPCD: A thread was started on thread_counter = 2
[06-03-2014 13:46:47] NPCD: ThreadCounter 3/5 File is 1401817602.perfdata.service
[06-03-2014 13:46:47] NPCD: Regular File: 1401817602.perfdata.service
[06-03-2014 13:46:47] NPCD: A thread was started on thread_counter = 3
[06-03-2014 13:46:47] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[06-03-2014 13:46:47] NPCD: Processing file 1401817587.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817587.perfdata.host
[06-03-2014 13:46:47] NPCD: Processing file '1401817587.perfdata.host'
[06-03-2014 13:46:47] NPCD: Processing file 1401817587.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817587.perfdata.service
[06-03-2014 13:46:47] NPCD: Processing file 1401817602.perfdata.service with ID 47688619694400 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817602.perfdata.service
[06-03-2014 13:46:47] NPCD: Processing file 1401817602.perfdata.host with ID 47688609204544 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817602.perfdata.host
[06-03-2014 13:46:47] NPCD: Processing file '1401817602.perfdata.service'
[06-03-2014 13:46:47] NPCD: Processing file '1401817587.perfdata.service'
[06-03-2014 13:46:47] NPCD: Processing file '1401817602.perfdata.host'
[06-03-2014 13:46:47] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:47:02] NPCD: Found 2 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:47:02] NPCD: DEBUG: load 1.210000/10.000000
[06-03-2014 13:47:02] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:47:02] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:47:02] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:47:17] NPCD: Found 6 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:47:17] NPCD: DEBUG: load 1.010000/10.000000
[06-03-2014 13:47:17] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:47:17] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:47:17] NPCD: ThreadCounter 0/5 File is 1401817617.perfdata.host
[06-03-2014 13:47:17] NPCD: Regular File: 1401817617.perfdata.host
[06-03-2014 13:47:17] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:47:17] NPCD: ThreadCounter 1/5 File is 1401817617.perfdata.service
[06-03-2014 13:47:17] NPCD: Regular File: 1401817617.perfdata.service
[06-03-2014 13:47:17] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:47:17] NPCD: ThreadCounter 2/5 File is 1401817632.perfdata.host
[06-03-2014 13:47:17] NPCD: Regular File: 1401817632.perfdata.host
[06-03-2014 13:47:17] NPCD: A thread was started on thread_counter = 2
[06-03-2014 13:47:17] NPCD: ThreadCounter 3/5 File is 1401817632.perfdata.service
[06-03-2014 13:47:17] NPCD: Regular File: 1401817632.perfdata.service
[06-03-2014 13:47:17] NPCD: A thread was started on thread_counter = 3
[06-03-2014 13:47:17] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[06-03-2014 13:47:17] NPCD: Processing file 1401817617.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817617.perfdata.host
[06-03-2014 13:47:17] NPCD: Processing file '1401817617.perfdata.host'
[06-03-2014 13:47:17] NPCD: Processing file 1401817617.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817617.perfdata.service
[06-03-2014 13:47:17] NPCD: Processing file '1401817617.perfdata.service'
[06-03-2014 13:47:17] NPCD: Processing file 1401817632.perfdata.host with ID 47688609204544 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817632.perfdata.host
[06-03-2014 13:47:17] NPCD: Processing file '1401817632.perfdata.host'
[06-03-2014 13:47:17] NPCD: Processing file 1401817632.perfdata.service with ID 47688619694400 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817632.perfdata.service
[06-03-2014 13:47:17] NPCD: Processing file '1401817632.perfdata.service'
[06-03-2014 13:47:18] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:47:33] NPCD: Found 2 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:47:33] NPCD: DEBUG: load 0.940000/10.000000
[06-03-2014 13:47:33] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:47:33] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:47:33] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:47:48] NPCD: Found 6 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:47:48] NPCD: DEBUG: load 0.730000/10.000000
[06-03-2014 13:47:48] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:47:48] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:47:48] NPCD: ThreadCounter 0/5 File is 1401817647.perfdata.host
[06-03-2014 13:47:48] NPCD: Regular File: 1401817647.perfdata.host
[06-03-2014 13:47:48] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:47:48] NPCD: ThreadCounter 1/5 File is 1401817647.perfdata.service
[06-03-2014 13:47:48] NPCD: Regular File: 1401817647.perfdata.service
[06-03-2014 13:47:48] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:47:48] NPCD: ThreadCounter 2/5 File is 1401817662.perfdata.host
[06-03-2014 13:47:48] NPCD: Regular File: 1401817662.perfdata.host
[06-03-2014 13:47:48] NPCD: A thread was started on thread_counter = 2
[06-03-2014 13:47:48] NPCD: ThreadCounter 3/5 File is 1401817662.perfdata.service
[06-03-2014 13:47:48] NPCD: Regular File: 1401817662.perfdata.service
[06-03-2014 13:47:48] NPCD: A thread was started on thread_counter = 3
[06-03-2014 13:47:48] NPCD: Have to wait: Filecounter = 4 - thread_counter = 4
[06-03-2014 13:47:48] NPCD: Processing file 1401817647.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817647.perfdata.host
[06-03-2014 13:47:48] NPCD: Processing file 1401817662.perfdata.service with ID 47688619694400 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817662.perfdata.service
[06-03-2014 13:47:48] NPCD: Processing file '1401817647.perfdata.host'
[06-03-2014 13:47:48] NPCD: Processing file 1401817647.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817647.perfdata.service
[06-03-2014 13:47:48] NPCD: Processing file '1401817662.perfdata.service'
[06-03-2014 13:47:48] NPCD: Processing file 1401817662.perfdata.host with ID 47688609204544 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817662.perfdata.host
[06-03-2014 13:47:48] NPCD: Processing file '1401817647.perfdata.service'
[06-03-2014 13:47:48] NPCD: Processing file '1401817662.perfdata.host'
[06-03-2014 13:47:48] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:48:03] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:48:03] NPCD: DEBUG: load 1.370000/10.000000
[06-03-2014 13:48:03] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:48:03] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:48:03] NPCD: ThreadCounter 0/5 File is 1401817677.perfdata.host
[06-03-2014 13:48:03] NPCD: Regular File: 1401817677.perfdata.host
[06-03-2014 13:48:03] NPCD: A thread was started on thread_counter = 0
[06-03-2014 13:48:03] NPCD: ThreadCounter 1/5 File is 1401817677.perfdata.service
[06-03-2014 13:48:03] NPCD: Regular File: 1401817677.perfdata.service
[06-03-2014 13:48:03] NPCD: A thread was started on thread_counter = 1
[06-03-2014 13:48:03] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[06-03-2014 13:48:03] NPCD: Processing file 1401817677.perfdata.host with ID 47688588224832 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817677.perfdata.host
[06-03-2014 13:48:03] NPCD: Processing file '1401817677.perfdata.host'
[06-03-2014 13:48:03] NPCD: Processing file 1401817677.perfdata.service with ID 47688598714688 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1401817677.perfdata.service
[06-03-2014 13:48:03] NPCD: Processing file '1401817677.perfdata.service'
[06-03-2014 13:48:03] NPCD: No more files to process... waiting for 15 seconds
[06-03-2014 13:48:18] NPCD: Found 2 files in /usr/local/nagios/var/spool/perfdata/
[06-03-2014 13:48:18] NPCD: DEBUG: load 1.290000/10.000000
[06-03-2014 13:48:18] NPCD: ThreadCounter 0/5 File is .
[06-03-2014 13:48:18] NPCD: ThreadCounter 0/5 File is ..
[06-03-2014 13:48:18] NPCD: No more files to process... waiting for 15 seconds
[root@nagios ~]#
tecnalb
Post
by tecnalb » Tue Jun 03, 2014 12:54 pm
Sure thing... I went ahead and opened a ticket with support... this seems to be taking forever to get a response.... Thanks for your wonderful assistance. By the way..
it's tail -25 /usr/local/nagios/var/perfdata.log.... not perdata... wouldn't want you to waste any customer's time.
Posts: 9117 Joined: Mon Sep 23, 2013 8:40 am
Post
by tmcdonald » Tue Jun 03, 2014 12:58 pm
The ticket just appeared in our system 20 minutes ago, and before answering we usually like to read over any relevant threads so we aren't asking questions that have already been answered here.
tecnalb wrote: it's tail -25 /usr/local/nagios/var/perfdata.log.... not perdata... wouldn't want you to waste any customer's time.
Yea, that was a typo.
ADD: This was caused by a discrepancy between two versions of check_icmp and their perfdata output. Details here:
http://support.nagios.com/forum/viewtop ... 19#p100919
