AD integration
dsdonut
AD integration
Post by dsdonut »
When the latest version of XI was released, mention was made for LDAP/AD authentication.
Where do you configure this? Is it built in, or is a pluggin required?
agriffin
Re: AD integration
Post by agriffin »
This is a separate component located here. After downloading it, you can install it in the XI web interface by going to Admin->Manage Components, and then uploading the zip file.
dsdonut
Re: AD integration
Post by dsdonut »
It looks as if that pluggin has been around for a while, as it is compatible with a 2009 release of XI.
At the bottom of this page it lists LDAP/AD as a new feature of the latest 2011 release.
http://www.nagios.com/products/nagiosxi/whatsnew
I took that to mean that it is supported as a new feature of XI. Is the same, older AD plugin still required?
agriffin
Re: AD integration
Post by agriffin »
dsdonut wrote:Is the same, older AD plugin still required?
Yes.
dsdonut
Re: AD integration
Post by dsdonut »
Then what's new? Why was LDAP/AD listed as a new feature of the latest release?
I'm ok installing the plugin, but it just doesn't make sense.
